Module Failed SCP dnld
mj11
Level 6
Level 6
Hi, I have a WS-SVC-IDSM-2 which is showing as PwrDown looking at the show power there is more than enough but there is an error message "Module Failed SCP dnld" does any body know why this is showing? it is something to do with the rom version.
Regards MJ
**please note I have posted this in the IDS section**
smothuku
Level 11
Level 11
Hi ,
The Failed SCP dnld means
This message indicates that the system was unable to download the runtime image to the
10GE module/processor because the download or the ASIC initialization did not complete in
the allocated time.
This occurs because the ASIC on module 1 failed to download it's runtime code from the NMP in the allotted time. When this problem happens, the supervisor automatically power the module down and try to download the microcode to it continously.
This is because the module is could be bad or not seated fully.
****Better go for replacement.
satish
Thanks for the response, I will get a replacement.
Thanks MJ
do you have any document for this?
