Automate Backup - SG Switches With HTTP/S Only
ksbolton1
Good day.
I've created a Python script that backs up most of my network devices via netmiko and CLI. Some of these switches are small business models (e.g. SG200 series) that only allow access via HTTP/S. Is there any standard solution for automating the backups for those?
6 Replies 6
Jaderson Pessoa
you can use network assistant or ccp to do it.
Jaderson Pessoa
*** Rate All Helpful Responses ***
Interesting. I've installed it and it seems like a decent tool, but how would I automate this? It looks like I'd have to write a script to interface with the Java applet.
I've found "Configuration Archive" but when I try to Back Up, I' m hit with an error message:
I'll look it up but I know I have no other TFTP applications running on the machine at the moment. None in services either.
Dear ksbolton1,
Have you finished your configuration?
Jaderson Pessoa
Yes, the switch is completely configured.
Please, if possible,
Mark it as solved and helpful
Thanks in advanced.
Jaderson Pessoa
This hasn't offered a complete solution to my query. How would I use CNA to automate the config backup for HTTP/S only switches?
