Autonomous access point
Sivakanth Akkapu
Community Member
Can someone help me urgently
AP(it's 1130AG) is not pinging from access switch even it's formed neigbhourship
when i issued the command "Sh cdp nei" it's showing on my access switch but not pining from switch
i checked vlan and ports status everything is fine.
please helpme urgently
im on production......
8 Replies 8
John Blakley
Can you post the config of the AP? Has it ever worked or is this a new install?
HTH, John *** Please rate all useful posts ***
Yes,this is new install
We can't help you if you don't tell us addressing information, configurations, etc...CDP is a l2 protocol which only tells us that that part is working. Other than that everything would be purely a guess. Again, can you post the config of the AP?
Ven Taylor
Level 8
Level 8
Can you ping the AP from anywhere else?
What is the switch port config for the AP?
Is this a good vlan with dhcp or does that AP have a static IP?
Ven
Ven Taylor
Alessio Andreoli
Level 11
Level 11
Try to issue
show cdp nei detail
share this info and the trunk config (uplink)
Alessio
Hi All,
issue has been resolved
we forgot  the comman "default-gateway" in AP..now it's working
thank you all for quick response
It's always the little things...
Ven Taylor
Naveen Kumar
Level 7
Level 7
FYI
Here is the installation and Troubleshooting guide for 1250 Series Autonomous Access Points:
http://www.cisco.com/en/US/docs/wireless/access_point/1250/installation/guide/125h_c3.html#wp1015872
