Hello, how can I avoid the need to enter an enable password upon login.
Here is my config:
Current configuration : 2297 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
username support privilege 3 secret 5 $1$e1En$YNav/fS5tV6T6.4L60u9c0
username myUser privilege 15 secret 5 $1$FDqZ$KjKCKXKMOINDCnfne2/VE/
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login CONSOLE local
aaa authentication enable default group tacacs+ enable
aaa authorization config-commands
aaa authorization exec default local if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ local if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
system mtu routing 1500
ip subnet-zero
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport trunk allowed vlan 57
switchport mode trunk
interface Vlan57
ip address 10.100.7.57 255.255.255.0
no ip route-cache
ip default-gateway 10.100.7.1
ip http server
ip tacacs source-interface Vlan57
tacacs-server host 10.21.250.212
tacacs-server timeout 10
tacacs-server directed-request
tacacs-server key RUc=U@3.n6:`%aZP3~nV
control-plane
line con 0
line vty 5 15
end
