Backbone Switch H/W Specifications
dahgenegweon
Community Member
Is there a backbone switch/router that supports at least 48-port 10/100/1000 ethernet, 8-port 100base-X SFP
,800 Gbps switching fabric performance, and provide at least 10 slots?
6513-E's switching fabric performance does not meet the above requirement since its maximum backplane BW is only 720 Gbps.
In regards to Nexus 7000 Series, it states that it delivers up to 480 Gbps of data throughput but offers
1.1 Tbps Full duplex (550 Gbps in each direction) Switch Fabric Interface as per Cisco's Data Sheet.
I am confused if this means Nexus 7000 Series does suffice the above requirements or not.
Thank you in advance
Leo Laohoo
This value is PER CHASSIS and not per slot.  Sup720 can support 40 Gbps per slot.
If you want higher per slot backplane then the next one in line would be the 4500R+E with Sup7E.
You want to go higher per slot backplane speed?  6500 with Sup2T.
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
The 6513, using a sup2t, has 80 Gbps to all slots; 2TB per chassis.
darren.g
Level 10
Level 10
The nexus 7000 series supports up to 550 Gbps per SLOT, with total switching fabric capacity between 7.7 and 17.6 Tbps per CHASSIS.
The trouble is, like msot Cisco card-based models, almost all of the M series cards (layer 3 capable cards) are over subscribed to the backbone.
You could put the following into a Nexus &k and get close to what you want
1 x N7K-M148GS-11L - 48 x 1 GE SFP based ports
1 x N7K-M148GT-11L - 48 x 10/100/1000 copper ports
Put them in with a SUP2 or SUP2E and 5 x FAB2 switching modules, and you'll get the throughput stated - 550 Gbps per card slot.
Cheers
