Help Configure Port Forwarding on Cisco 887
khonhow_tan
I need to configure the port forwarding on Cisco 887 to forward port  22 on Public IP to a LAN IP port 2200.
I don't know anything on Cisco  router at all, beside telnet to the cisco and quit . Please provide step  by step command.
Thanks a lot.
2 Accepted Solutions
enable ----> enter enable password if any configured
config t
ip nat inside source static tcp 192.168.1.x 2200 interface dialer 0 22
int dialer 0  ----> I suppose this is your WAN interface
ip nat outside
int vlan 1  ---> I suppose this is your LAN interface
ip address 192.168.1.x 255.255.255.0
ip nat inside
Regards.
Alain
I forgot to mention that you must issue either a wr command or a copy run start command for the settings to be saved in the startup config and stay after a reboot. Of course this is valid for all configs you do on the device.
Regards.
Alain
9 Replies 9
cadet alain
on LAN facing interface: ip nat inside
on WAN facing interface: ip nat outside
then in global config:  ip nat inside source static tcp x.x.x.x 2200 interface x 22  where x.x.x.x is LAN IP and interface is WAN interface
Regards.
Alain
Hi Alain
Thanks for the reply.
Sorry i am totally new to the Cisco router, what are the command to input after i telnet to the cisco router ?
config t
ip nat outside
ip nat inside
Regards.
Alain
Thanks again for your kind help Alain. I will give it a try.
Yeah ! it works. You are great
One last question, is the settings persistant even the router is reboot ?
of course it is.
Regards.
Alain
excellent
Regards.
Alain
thanks. i will do that
