backup for cisco switch
engbandar
what is the back up for switch and what is the professional back up for switch and complete back up for switch
HI
The switch has two configs ie.
1.Running-config which is the config the router is using currently and operatinal,this config will be erased if u restart the router without saving the configs.
2.Startup config this config is in nvram and the router used this config when starting up
U need to take the backup of startup config.
If possible u can take the backup of the IOS which will be flash.
Mahmood
Sudhir Menon
pls elaborate
engbandar
for configuration and IOS ..etc
HI
Mahmood
