Bandwidth division into two LAN with same subnet
Muhammad Younus
Dear,
I know it is very old topic, but I am getting problem. I have ciso 2821 router with 8 Mbps say with ip 192.168.1.1 configured with NAT.
I want to devide internet bandwidth between my two other networks with seperate routers having ip address 192.168.1.2 and 192.168.2.3. I configured NAT on them and my 2821 is WAN router for other two. I want to limit 192.168.1.2 to 5 Mpbs and other to 3 Mbps. Kindly help me in this regards.
Thank you.
Julio E. Moisa
You can use Shape or Police through MQC, the first one can be used on outbound direction it works with queues, now Police works dropping packets and it can be deployed for inbound and outbound traffic.
access-list 100 permit 192.168.1.0 0.0.0.255 any
access-list 101 permit 192.168.2.0 0.0.0.255 any
class-map match-all SUBNET1
match access-group 100
class-map match-all SUBNET2
match access-group 101
policy-map INTERNET-POLICY
class SUBNET1
police 5000000 conform-action transmit exceed-action drop
class SUBNET2
police 3000000 conform-action transmit exceed-action drop
interface g0/0
description TO-ISP
service-policy output INTERNET-POLICY
or
class SUBNET1
shape average 5000000
class SUBNET2
shape average 3000000
interface g0/0
description TO-ISP
ip address x.x.x.x y.y.y.y
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
class SUBNET1
class SUBNET2
interface g0/0
description TO-ISP
or
class SUBNET1
class SUBNET2
interface g0/0
description TO-ISP
Hope it is useful
Sure it is helpful, thank you for your solution. What if I want to use within same subnet bu different ip i.e. 192.168.1.2 and 192.168.1.3. Should I use the same or some other configuration required, Kindly explain plz.
Just to add to what Julio has already noted. . .
Since policers or shapers set hard caps, another approach is to use a hierarchical policy, shaping for the overall aggregate allowance (8 Mbps, in your case) and using a child policy to split the bandwidth as you desire.
The advantage of this approach is it allows one VLAN to use bandwidth not otherwise being used by the other VLAN.  Of course, that can be a disadvantage if you truly want to always limit the amount of traffic to a VLAN regardless of available bandwidth.
