Bandwidth History per Switchport
hippieboy9
I have been looking for a way to look at bandwidth usage per port so I can isolate bandwidth hogs on the network. Is there an easy way to do this? I have tried Cisco Network Assistant but I could not get it to show me more than one port at a time.
Thanks.
Edison Ortiz
What model of switch are we dealing with?
Some models support NetFlow.
__
Edison.
It is a 3560.
Thanks.
3560's don't support netflow. For an instantaneous look at all ports and the switch fabric use the "show controllers utilization command . This does give utilization per port for that instant you issue the command , very nice and easy to look at .
