Bandwidth limitation on switch and router
ANGELO DE MASI
Hi, I'm workin gon this scenario: a router 2821 works as internet router and it's connected to a 3750 switch. Every switch port is configured as routed port and it is linked to a different customer network. All customers share the same internet bandwitdth so I should need to limit accordingly internet bandwidth use. Can you please give me and advise to implement this configuration?
First of all, where it is more convenient to implement rate limit and in which direction? Do I need to use CAR or Traffic Policing? I already tried both but it seems nothing change. How can I verify and monitor if CAR or Policing are tightly working? More over on switch I can't apply output policy on intefaces.
I will appreciate very much any kind suggestion. Thandk you in advance.
If you need more information about my scenario, please ask me.
angelo
paolo bevilacqua
You can use traffic-shaping for a fixed limit.
Or a percent that applies only when link is congested.
Both in PBR likely under an hierarchical shaping.
I recommend you don't anything on the switch.
In all cases, read QoS about QoS in cisco standard documentation.
Hi Paolo,
first of all thanks for your answer.
You suggest dont' do anything on the switch, so do I need to apply QoS only on customer's router?
I applied a configuration like the following to limit customer's bandidth to 10Mb, is it correct?
Example:
class-map match-all Rate-Limit-Out
match access-group name ACL-Rate-Limit
class-map match-all CIR
policy-map CCP-QoS-Policy-1
class CIR
   police cir 10000000 bc 2000000 be 4000000
     conform-action transmit
     exceed-action drop
policy-map CCP-QoS-Policy-2
class Rate-Limit-Out
     exceed-action drop
interface FastEthernet0/0
description Interfaccia Outside verso Fibra
service-policy input CCP-QoS-Policy-1
service-policy output CCP-QoS-Policy-2
ip access-list standard ACL-Rate-Limit
remark CCP_ACL Category=256
permit any
Every other tips will be very appreciated.
Thanks a lot in advance
regards
angelo
