Banner Alignment Problem
jmoss1
Level 3
Level 3
Hi when using aaa authentication on my 3560 switches the banners remove all the blank space i put in and left align everything. without aaa auth it works ok. any ideas
Leo Laohoo
If you are using the new 12.2(50)SE or 12.2(50)SE1 IOS then it's a known bug. Downgrade to the 12.2(46) if you don't need the extra features of the new release.
Hope this helps. Please rate when applicable.
Leo Laohoo
yes we are on 12.2(50)SE as we need the features, thanks i'll wait then until bug is fixed in later ios release
Leo Laohoo
Thanks for the rating.
