Banner not showing in Cisco Multi-Layered Switch
utkarshahuja007
Hey, I have configured a simple banner in Cisco Multi-Layer switch Model- 3650 but when I reload the switch the banner is not showing. I checked in show running-configuration and it is present in both startup and running configuration but when I restart the system it only shows the default banner.
which version of Packet Tracer are you using ? I just tested in version 8.1 (the latest), and the banner stays in the config even after reloading:
3650#conf t
3650(config)#banner motd ^C
Authorized Persons Only
^C
3650(config)#end
3650#wr
3650#copy run start
3650#reload
Hello
How are you connecting to the switch - reverse telnet or console?
Kind Regards
Paul
