Banner on ASA 5520
scooter817
Level 2
Level 2
I wanted to know if anyone can tell me what is the command that will allow me to copy and paste a banner statement on my ASA.
I'm trying to put the same banner on the ASA as my routers and switches. when i enter config mode and type banner login and
try to paste the banner i get errors but if i just enter one line something like, This is a restricted system it works, I just can't
copy and paste the entire banner in.
JORGE RODRIGUEZ
Level 10
Level 10
Reading the guidelines on banners for firewalls  it states.
quote from link bellow
"Multiple lines in a banner are handled by entering a new banner command for each line that you wish to add. Each line is then appended to the end of the existing banner "
Reference this link on  some basic  guidelines on banner usage in asa's
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/b.html#wp1355378
Jorge Rodriguez
JORGE RODRIGUEZ
Level 10
Level 10
Jorge Rodriguez
Thanks a lot, i just applied the banner to the ASA's and the commands worked perfect
