Basic 3850 Management port and remote SSH access with Local User auth!
vodafonegsmart
Hi guys,
Im really struggling to get this working.
I just want remote SSH to my 3850 switch via its management interface yet I cant get it to use damn local authentication no matter what.
The Cisco DOC's appear wrong as the commands just dont work.
I have set an IP on my g0/0 interface.
I can SSH to it, enter my user and password and it just doesnt let me in.
I put these commands in, but it still doesnt work.
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization network default local
I created a username password for Priv 15.
What am I doing wrong?
I just see these lines in the console:
*Mar 30 05:31:22.402: AAA/AUTHEN/LOGIN (00000FB5): Pick method list 'default'
*Mar 30 05:31:25.376: AAA/AUTHEN/LOGIN (00000FB5): Pick method list 'default'
*Mar 30 05:31:30.735: AAA/AUTHEN/LOGIN (00000FB5): Pick method list 'default'
It lets me login with the "admin" user just not one that I create.
Thansk
g
6 Replies 6
apasillas
You need the vty lines
conf t
line vty 0 4
 login local
 transport input ssh
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_53_se/configuration/guide/2960scg/swauthen.html#wp1227177
Yep, They are there too.
I can login as mentioned with the "admin" username. Just cant login with any other username I make?
can you upload the full code please, you can erase interfaces and that stuff.
I think that's by default and by designed; btw admin is username , what's password ?
Robert Falconer
If you just want to use local auth, you shouldn't need any AAA settings.
Configuring vty with 'login local' is enough. I use it in my lab.
username xxxxxxxx privilege 15 password 7 xxxxxxxxxxxxxxxx
no aaa new-model
line vty 0 4
 password 7 xx
 login local
 transport input ssh
line vty 5 15
 password 7 xx
 login local
 transport input ssh
