Basic Cisco Catalyst 4900m Interface Configuration Question
Hello Everyone,
I am simply trying to get my cisco switch to allow traffic on 3 TenGigabitEthernet ports under one vlan in layer 2 mode.  I have the servers connected to the switch ports now and I have pretty much done the bare bones switch configuration so far in accordance to the get me started guide located here
on the CD they sent me.
At this point I cannot ping accross the switches.  When I do a show ip interface brief
TenGigabitEthernet1/1  unassigned   YES   unset  up      up
TenGigabitEthernet1/2  unassigned   YES   unset  up      up
TenGigabitEthernet1/4  unassigned   YES   unset  up      up
The ports seem to be up.  I was thinking maybe I need to configure access control so I then created an IP access-list to permit all TCP and applied it to all the ports both outgoing and incoming.  I even started to configure a mac access-group to allow all mac addresses.  And I did do a no shutdown command on the ports also.
So basically I am just confused as to what I need to do to allow traffic to go through the interfaces.  I honestly would think pretty much just plugging in the cables it should work.
Any help/comments/suggestions would be appreciated,
Dan
Hello Dan,
Thank you for posting the information. Okay. This looks fairly nice - let me suggest a few things here:
  1. Remove the ACLs from your ports. Not only are the unnecessary, they are actually harmful at this point (note that for example, pings are ICMP, not TCP, so in trying to permit the connectivity, you have prohibited the pings from ever working).
  2. Try to configure the ports as follows:
interface Ten1/1 - 8
switchport mode access
switchport access vlan 1 ! This command is for completeness, it is already present though invisible
spanning-tree portfast
This way, we will force the ports to act as access ports in VLAN1 and to become unblocked in STP immediately as they are connected. Once again, please remove the ACLs from the ports.
Best regards,
Peter
5 Replies 5
Peter Paluch
Hello Dan,
Can you post the output of the following commands?
show running-config
show vlan brief
show spanning-tree
Thank you!
Best regards,
Peter
Hey Peter,
Thanks for your attention and help.  I have posted the output below.  Thank again.
show running config
bswitch#show running-config
Building configuration...
Current configuration : 1735 bytes
! Last configuration change at 13:05:02 UTC Mon Jan 7 2013
! NVRAM config last updated at 11:53:49 UTC Mon Jan 7 2013
version 12.2
no service pad
service compress-config
hostname labswitch
boot-start-marker
boot system flash bootflash:cat4500e-ipbase-mz.122-53.SG5.bin
boot-end-marker
####enable secret 5
enable password ###############3
username test privilege 15 password 0 hackme4fun
no aaa new-model
ip subnet-zero
ip domain-name cyber
ip vrf mgmtVrf
vtp mode transparent
power redundancy-mode redundant
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1
ip vrf forwarding mgmtVrf
ip address 192.168.1.29 255.255.255.0
speed auto
duplex auto
interface TenGigabitEthernet1/1
ip access-group ip-acl in
ip access-group ip-acl out
mac access-group mac-acl in
interface TenGigabitEthernet1/2
interface TenGigabitEthernet1/3
interface TenGigabitEthernet1/4
interface TenGigabitEthernet1/5
interface TenGigabitEthernet1/6
interface TenGigabitEthernet1/7
interface TenGigabitEthernet1/8
interface Vlan1
ip address 192.168.1.30 255.255.255.0
ip http server
ip http authentication local
ip http timeout-policy idle 180 life 360 requests 25
ip access-list extended ip-acl
permit tcp any any
banner motd ^Comans Cyber Lab
Cyber Lab^C
line con 0
stopbits 1
line vty 0 4
password terminal-password
login
line vty 5 15
login
end
show spanning-tree
bswitch#show spanning-tree
VLAN0001
  Spanning tree enabled protocol ieee
  Root ID    Priority    32769
             Address     d48c.b5d0.b2c0
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32769  (priority 32768 sys-id-ext 1)
             Aging Time 300
Interface           Role Sts Cost      Prio.Nbr Type
Te1/1               Desg FWD 2         128.1    P2p
Te1/2               Desg FWD 2         128.2    P2p
Te1/4               Desg FWD 2         128.4    P2p
labswitch#
show vlan brief
labswitch#show vlan brief
VLAN Name                             Status    Ports
1    default                          active    Te1/1, Te1/2, Te1/3, Te1/4
                                                Te1/5, Te1/6, Te1/7, Te1/8
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
Hello Dan,
Best regards,
Peter
Thanks for your help Peter,
You were pretty much spot on.  I had to add the range command in the code that you gave.  Then it still did not work.  Then I reconfigured the IP's on the servers and then things worked so thanks.
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
BTW, regarding Peter's suggestion for using portfast, you can often make it the default for access ports.  This makes it less likely to "forget" to configure it for an edge access port, and reduces the "clutter" of the config.  For access ports that should not be using portfast, you can disable it per port which also "flags" that access port as unusual.
Also, when using portfast, some like to also enable BPDUguard for the same ports.  It too can be set as an access port default and, also if enabled as a default, overridden per port too.
