Basic clarification on IP address on VLAN interfaces
news2010a
Level 3
Level 3
Folks, can you clarify the following to help me understand whether I should assign an IP to identify SWITCH2 as shown below:
[SWITCH1 f0/1-f0/23 vlan3
f0/24 trunk allow vlan 3 connected to SWITCH2]
[SWITCH2 f0/1-f0/22 Vlan 1]
F0/24 trunk allow vlan 3 connected to SWITCH1. F0/23 is trunk Vlan3 uplink to a Layer 3 switch]
On SWITCH2, I will do:
int vlan 3
ip add 10.3.33.1 255.255.255.0
Question:
Do I have any technical reason to also assign an IP address
to the vlan 3 on SWITCH1? The benefit of assign an IP to the VLAN 3 in this case is just to identify the switch with an IP address, correct?
jpoplawski
Technical reason, no you don't need an IP on the switch. It would be nice and/or recommended to remote support it, wouldn't it? For example you want to check port states, speeds, etc. A lot more convenient to access the CLI remotely.
Benefit would be remote support, monitoring, SNMP, etc.
Hope this helps, rate if it does!
JB
jpoplawski
JB
Jon Marshall
Marlon
"Do I have any technical reason to also assign an IP address to the vlan 3 on SWITCH1?"
Yes, for management purposes. Assigning an IP address to the vlan 3 interface will allow you to connect to that switch remotely if you need to modify the configuration.
Jon
