Basic commands on the ME1200 do not work
bholden3877
Greetings, I am trying to configure an ME1200 right out of the box, and some of the most basic commands do not work. For instance when I type in show run I get an error message command not permitted. If I type a question mark I get the following:
ACLDefinition Template for actual ▒CL definitions
Diagnostics Diagnostics Tests
EpsPortType Provision eps
ErpsPortType Provision Erps
FlexlinksPortType Provision Flexlinks Services
LSTPortType Provision LST Services
LinkOamPortType Provision linkoam
NtpPortType NTP provision
OperationsMepPortType Enables FM and PM on Mep
PTPPortType ME1200 PTP operations
ProvisionACL Enter Cisco ACL Provisioning mode
ProvisionConfigManagement Enter Cisco ConfigMgmt Provisioning mode
ProvisionEVC Enter Cisco EVC Provisioning mode
ProvisionL2CPPortType Provision L2CP service
ProvisionLacpPortType Provision LACP service
ProvisionLldpPortType Provision lldp
ProvisionMacTableSecurityType MAC Address Table Management
ProvisionMepPortType Provision MEP
ProvisionNIDMgmtType Provision NID Management
ProvisionNotifications Enter Notifications Configuration mode
ProvisionPhyPortType Physical Port Configuration
*ProvisionPortVlanPortType Provision Vlan and SwitchPort Service ProvisionQos QOS Provisioning
ProvisionSnmpConf Provision Snmp Service
ProvisionStormControl Provision Storm Control Service
ProvisionStpPortType Provision STP Services
ProvisionSystemType show flash
RFC2544Por▒U▒▒ RFC2544 port type
ReachabilityPortType Enter Reachability Provisioning mode
SFlow sFlow operations
Span Enter SPAN and RSPAN Provisioning mode
SyncE Set SyncE configuration
Syslog Syslog Properties and Methods
UDLDPortType Provision UDLD Configuration
ciscoY1564 Enter Cisco Y1564 Provisioning mode
do To run exec commands in config mode
exit Exit from EXEC mode
help Description of the interactive help system
https Enter HTTPS Provisioning mode
logout Exit from EXEC mode
more Display file
template Cisco template wise debug mode
#L
This is the XML command set. I do not want to use the ZTP (Zero Touch Provisioning) or 920 as a controller. I have other ME1200's in the field acting as standalone switches and they display a normal range of the subset of IOS commands.
Has anyone else encountered this?
22 Replies 22
So now if you do a 'reboot cold' it comes back with the initial default and not the startup configuration ?
You don't need to erase the default-config, I don't even think you can, since it is 'r' read-only...
Correct.
Dustin,
you are doing everything by the book...
The only think I can think of is a firmware upgrade (page 1-31 of the attached guide). Also, can you post the output of 'show version', I want to check for bugs, always a possibility...
http://www.cisco.com/c/dam/en/us/td/docs/switches/metro/me1200/icli/configuration/guide/me1200-iCLI-config-guide.pdf
Yes, I was going to try and download an updated firmware/version. However my smartnet apparently hasnt been associated yet, so I am waiting for that so I can download.
# sh ver
MEMORY : Total=439639 KBytes, Free=408202 KBytes, Max=388125 KBytes
FLASH : 0x40000000-0x41ffffff, 512 x 0x10000 blocks
FLASH : 0x42000000-0x43ffffff, 512 x 0x10000 blocks
MAC Address : 34-62-88-25-97-dc
Previous Restart : Cold
System Contact :
System Name :
System Location :
System Time : 1970-01-01T00:06:05+00:00
System Uptime : 00:06:05
Active Image
Image : me1200-universal-mz.156-1.SN3.img (primary)
Version : ME1200 OS Software Build 15.6-1.SN
Date : 2016-04-26T08:18:47-07:00
Code Revision : v156_1_sn_xe317_throttle-BLD-v156_1_sn_xe317_throttle.V156_1_SN3 [V156_1_S_FC4 %LABEL_REF_LABEL%]
Alternate Image
-- more --, next page: Space, continue: g, quit: ^C                                                   ---------------
Image : me1200-universal-mz.156-1.SN3.img (backup)
Bootloader
Image : RedBoot (bootloader)
Version : version 1_13_Cisco
Date : 09:10:10, Sep 1 2014
SID : 1
Port Count : 6
Product : Cisco ME1200 Switch
Software Version : ME1200 OS Software Build 15.6-1.SN
Build Date : Tue Apr 26 08:18:47 PDT 2016
Latest image downloaded. i'll update on if upgrade works.
Looks like that may have worked
Dustin,
I hope that worked. I could not really find any bugs, there is one where the interfaces are returned to default after a reload, but not the entire configuration:
ME1200 Interface Config Returned to Default After Reload
CSCut59692
Description
Symptom:
Interfaces on the ME1200 switch platform are returned to their default configuration after a reload or power outage
Conditions:
Only occurs in standalone mode
Observed in all current versions of IOS on this platform.
Workaround:
None
Further Problem Description:
Customer Visible
Notifications
Save Bug
Open Support Case
Was the description about this Bug Helpful?(0)
Details
Last Modified:
Jan 29,2017
Status:
Fixed
Severity:
1 Catastrophic
Product: (1)
Cisco ME 1200 Series Carrier Ethernet Access Devices
Support Cases:
Known Affected Releases: (3)
15.4(2)S
15.4(3)S
15.5(1)S
Known Fixed Releases: (17)
15.6(0.4)S
15.5(3)SN
15.5(3)S1a
15.5(3)S1
15.5(3)S0a
15.5(3)S
15.5(2.21)S0.12
15.5(2.21)S0.6
15.5(2)SN
15.5(2)S1
15.5(2)S0.6
15.5(1)S4.21
15.5(1)S3
15.5(1)S2.15
15.5(1)S2.1
15.4(3)S4
15.4(3)S3.3
Dustin Flint
Are you still having this issue? If not how were you able to fix it? This is my first 1200 I am testing out and I want to configure it to be stand alone with normal IOS commands. Thanks.
