Basic Network Config - Not Working
ACE_9
Visitor
I have a basic set up that does not seem to be working as expected.
this is all physical set up which consist of:
Cisco Router - 1900
Switch - 2960-X
2 Win 10 Machines
Set up:
Router 1 - Fast0/0 - Ip 24.17.2.1 /24
PC 1 - 24.17.2.3 / 24 / DG 24.17.2.1
PC 2 - 24.17.2.4 / 24 / DG 24.17.2.1
On the switch i have put all the interfaces on Vlan 22.
Each host can ping the router but they cannot ping the switch (Vlan 22) or each other.
Can anyone shed some light on what the issue is.
Thanks.
A
Will you please check/disable your Win10 firewalls.
Best regards,
Antonin
19 Replies 19
Jon Marshall
On the switch make sure the SVI for vlan 22 is up/up - "sh ip int br | inc Vlan".
On the PCs check for firewall which is blocking incoming ICMP.
Jon
Hi Jon,
SW1 is showing:
Vlan22 24.17.2.2 YES manual up up
Also on both hosts: File and Printer Sharing (Echo Request - ICMPv4-In) is enabled.
Still hosts cant ping each other or the Vlan. They can only ping Router?
Thanks.
A
Can the router ping the hosts ?
Jon
Georg Pauwen
make the changes marked in bold to your configurations:
R1#show run
Building configuration...
Current configuration : 1040 bytes
! Last configuration change at 11:40:47 UTC Thu Feb 21 2019
version 15.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
cts logging verbose
license udi pid CISCO1921/K9 sn FCZ1928924S
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.22
encapsulation dot1q 22
ip address 24.17.2.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
SW1#show run
Current configuration : 1769 bytes
! Last configuration change at 19:57:38 UTC Mon Jan 24 2000
version 15.0
no service pad
hostname SW1
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c2960x-24ts-l
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
interface GigabitEthernet1/0/1
description Trunk to Router
switchport mode trunk
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
switchport access vlan 22
switchport mode access
spanning-tree portfast
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
no ip address
interface Vlan22
ip address 24.17.2.2 255.255.255.0
ip default-gateway 24.17.2.1
ip http server
line con 0
line vty 5 15
End
Georg
Why are you suggesting to use a trunk as it should work fine as it is.
Jon
Hi Greg,
I applied your settings, please see attached. Same issue still, hosts can only ping router. However, router cant ping hosts.
Thanks.
A
On the switch, remove the line marked in bold (no switchport access vlan 22😞
--> switchport access vlan 22
Hi Georg,
i have done that please see attached. Still no difference.
A
Jon
as Jon suggested, your setup should work as is/was. The trunk would be an alternative, my assumption was that since you don't use the default Vlan (1), you probably need more Vlans in the future. hence the router-on-a-stick suggestion.
I have the exact same setup in GNS3, and it works fine What is the output of 'ipconfig /all' from the Windows machines ?
The only thing I can think of is to delete interface Vlan 1 from the switch (no interface vlan 1), that is the only difference between your and my setup...
Hi Georg,
I tried to remove Vlan 1:
SW1(config)#interface vlan 1
SW1(config-if)#no interface vlan 1
% Default interface VLAN 1 may not be deleted.
SW1(config)#Default interface VLAN 1 may not be deleted.
Interface Vlan1 set to default configuration
I don't know what the issues could be, should i factory reset the switch and router and try again?
A
Best regards,
Antonin
Hi To All,
After going into Windows defender Center and disabling all firewall protection settings all hosts can ping each other and the router.
Thank you all for the expert help!!
Ace
Just out of curiosity, why are you using Vlan 22 and not the default Vlan (1) ?
