Basic Network Load Balancing - 2xWindows 2003 Servers
peter_farmer
Community Member
Hi All,
We have two web-servers running the same front-end application.
One server is a physical server directly connected to our core switch - the server is a Virtual Server running in a VMWARE environment which resides on IBM blade servers (IBM Bladecentre.)
We have 2x4500R switches.
We basically want to do some load-balancing between the two - not so much for the actual load itself but for redundancy so if one server isn't availble, we don't have to change DNS entries or worry about asking users to wait for DNS round-robin.
Can someone point me in the right direction on how to:
1. configure NLB - both server and switching
2. principles for getting it to work with a VMWARE environment
I'm a little confused on what exactly needs to be done to get it to work correctly.
Any help would be great!
-Pete
hi peter
yes, arp and mac entries on the core switch. the VMs we were loadbalancing could be on any of 4 or 5 enclosures so our mac entries looked something like:
mac-address-table static xxxx.xxxx.xxxx vlan yyy interface Po1 Po2 Po5 Po6 Po9 Po10 Po12 Po13
we've since moved to a hardware solution for loadbalancing but the above config worked pretty well for us.
hth
andy
andrewswanson
Level 11
Level 11
Thanks Andy,
Did you configure the arp and mac entries on the core switch/router? The servers span over 3 different switches and the VM is connected over PortChannel trunks.
hi peter
hth
andy
