basic NTP Configuration
henokk601
Level 2
Level 2
Hi There
i have VSS configured 4500 series switch and i need it to be NTP server and the other devices to sync clock from this server and i want the basic configuration only  ?
For the server:
ntp master 7
ntp update-calendar
ntp server <Public Server address>
clock timezone <Your Local Time Zone>
and for the client:
ntp update-calendar
ntp server <NTP Server Switch IP>
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
Here I am sharing the NTP configuration for your switch:
ntp master 7
ntp update-calendar
But keep in mind that it is not recommended to keep your switch as NTP master. It is advised to use an NTP master as your servers as AD/DNS/DHCP or any trusted public source.
Deepak Kumar
Deepak Kumar,
Hi Deepak kumar
should i run this command both on client and server switches ?
For the server:
ntp master 7
ntp update-calendar
and for the client:
ntp update-calendar
Deepak Kumar
Deepak Kumar,
Deepak kumar
Thanks a lot !!
