cisco isr 4431 router Interface NVI0 problem
pinjar84062
 When i input a interface nvi 0 command on isr 4431 router below error show:
HO-DATA-ROUTER(config)#interface nvI 0
% Invalid input detected at '^' marker.
Please suggest me how i solve this problem?
Deepak Kumar
This interface is used ONLY when the ‘ip nat enable’ is enabled. This interface can be found with the command ‘show ip interface brief’ or ‘show interfaces’  but you can't configure this interface. NAT Virtual Interface; NVI removes the requirements to configure an interface as either NAT inside or NAT outside.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
