Basic Routing. Trying to learn. Need help.
Chris Mickle
I just bought a Cisco study lab in order to try to further teach myself about routing and switching on Cisco devices. I have been doing some reading and decided that I would design and build my own topology using the equipment I purchased. I have (2) 1721 routers, (2) 2610XM routers, (1) 2811 router and (3) 2960 switches. I decided that for my first project, I would try to use the routers to simulate two different LANs connected to their ISPs which were connected to the real internet. My topology is as follows...
Please forgive the crudeness of the above diagram. Hopefully it is clear what I'm trying to do. The two 1721s that are acting as the "internet gateways" are running DHCP on their Ethernet interfaces and NAT. All routers are running RIP V1. Everything seems to work as it's supposed to except that the 2811 is supposed to provide access to the real internet via my LAN and it does not. I can ping each computer from the other and I can ping all the interface IPs on each router from both PCs and from all the other routers. I can ping all the way to IP address 192.168.0.200 which is the IP of F0/0 on the 2811 that is connected to my LAN. From the 2811, I can ping 192.168.0.1 which is my LAN firewall's inside interface. I worked on it for several hours yesterday and I have just run out of ideas. I know that I am missing something, I'm just not sure what it is.
Any help would be much appreciated.
17 Replies 17
Could you please do me one last favor and review my router config? I want to make sure that what I have done is correct.
Thanks.
Current configuration : 1783 bytes
version 12.4
hostname R1
boot-start-marker
boot-end-marker
enable secret 5
no aaa new-model
resource policy
clock timezone EST -5
clock summer-time EDT recurring
ip subnet-zero
ip cef
ip domain name
username router privilege 15 secret 5
interface FastEthernet0/0
 ip address XXX.XXX.XXX.5 255.255.255.248
 ip nat outside
 duplex auto
 speed auto
 standby timers 254 255
 standby preempt
 standby 1 ip XXX.XXX.XXX.1
 standby 1 mac-address 0000.0000.0001
 standby 2 ip XXX.XXX.XXX.2
 standby 2 mac-address 0000.0000.0002
 standby 3 ip XXX.XXX.XXX.3
 standby 3 mac-address 0000.0000.0003
 standby 4 ip XXX.XXX.XXX.4
 standby 4 mac-address 0000.0000.0004
interface FastEthernet0/1
 ip address 10.0.0.6 255.255.255.248
 ip nat inside
 duplex full
 speed auto
 no mop enabled
interface Serial0/0/0
 ip address 172.16.10.1 255.255.255.252
 ip nat inside
ip classless
ip route 0.0.0.0 0.0.0.0 XXX.XXX.XXX.6
ip http server
ip http authentication local
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source list acl-inet interface FastEthernet0/0 overload
ip nat inside source static 10.0.0.1 XXX.XXX.XXX.1
ip nat inside source static 10.0.0.2 XXX.XXX.XXX.2
ip nat inside source static 10.0.0.3 XXX.XXX.XXX.3
ip nat inside source static 172.16.10.2 XXX.XXX.XXX.4
ip nat inside source static 10.0.0.5 XXX.XXX.XXX.5
ip access-list standard acl-inet
 permit 10.0.0.0 0.0.0.7
ip access-list standard lab-inet
 permit 172.16.10.0 0.0.0.7
control-plane
line con 0
line aux 0
line vty 0 4
 password
 login
scheduler allocate 20000 1000
end
Chris
There are so many possibilities for issues with router configuration (especially in things that perhaps should be in the config but are not) that it is quite difficult to say that a router config is 100% correct. But I will say that reviewing your config I do not see any particular issues in it.
Rick
Rick
Great! That's all I wanted to know. Thanks a lot!
