2960 default brackets
jcarvalh
Level 4
Level 4
Anyone knows the part number for the default bracket that come with all non compact switchs ?
I need to order some and I cannot find the correct part number. All I can find are optional brackets part number but I want part number for the ones that come with the switch.
Joao.
Mark Malone
This looks to be the part number ----P/N 800-16852-02
Hello.
Thanks but I tried that PN on CCW and it does not exist.
João.
