Basic switch-to-switch link question
HiSparx
Community Member
I have 2 - 3550-48 port switches linked to a 3550-12T. Everything seems to be functional. However, I notice there are a LOT of dicarded packets on the ports between the switches. I was just wondering if this is normal to see for switch-to-switch ports.
bjw
Level 8
Level 8
Discards are bad. Are you using simple trunks or Etherchannel links? can you provide the configs of three switches?
HiSparx
Community Member
We are using simple trunking from what I can tell. However, it looks like there might be some unneccesary configuration lines under each port. This was setup by someone else.
The core switch (3550-T) ports are configured like:
interface GigabitEthernet0/12
description swx-chi-dc-access2
switchport access vlan 254
switchport trunk encapsulation isl
switchport trunk native vlan 900
switchport mode trunk
mls qos trust cos
auto qos voip trust
macro description cisco-switch
wrr-queue bandwidth 10 20 70 1
wrr-queue queue-limit 50 25 15 10
wrr-queue cos-map 1 0 1
wrr-queue cos-map 2 2 4
wrr-queue cos-map 3 3 6 7
wrr-queue cos-map 4 5
priority-queue out
spanning-tree link-type point-to-point
Each of the Access Switch (3550-48) ports are configured like:
interface GigabitEthernet0/2
no ip address
Thanks for the advice.
I could be wrong, but here goes. Since priority queueing is enabled on the 3550-T, the higher priority queues are starving the lower queues and causing the packet drops.
http://www.cisco.com/warp/public/473/187.html
