09-25-2018 11:01 AM - edited 03-08-2019 04:14 PM
Hello
I need some help setting NEXUS 3132Q-V with basic switching and vlans
1 site I have router/firewall with DHCP and DNS
other site server with esxi with few VMs Windows Servers
between them I have NEXUS 3132Q-V
I am trying to get NEXUS to do trunking between the router and the server
Let say on NEXUS port 1 is connected to the router and port 32 to the server
Here is my configuration on the nexus
config
interface eth1/1
speed 40000
switchport mode trunk
switchport trunk native vlan 1
switchport trunk allowed vlan 10,20,30,40,50,60,70,80,90,100
description TRUNK_PF
no shutdown
exit
config
interface eth1/32
speed 40000
description TRUNK_ESX
no shutdown
exit
That should pass all defined vlans trough? but I can't ping any host on esxi
Thank you
Solved! Go to Solution.
10-04-2018 01:23 PM
Do you have windows firewall or linux iptables on the server? Can you use Wireshark or iptables to see if the packets are actually getting there. As ping from server to router/firewall works I will exclude problems on the L2.. Looks more something is blocking icmp echo towards the server..
09-25-2018 11:05 AM
Yes that should work. Can you post the following?
- show interface status
- show interface trunk
- show mac address-table
ADP
09-26-2018 01:59 PM
09-26-2018 03:40 PM
Those commands are not helping as you switch is only performing L2, please provide the ones I asked you earlier:
ADP
09-26-2018 02:20 PM - edited 09-26-2018 02:22 PM
hello
sorry for inconvenience the server I've used as a router has some firmware issue so I put it on an other server with esxi and the same router but visualized only 1 vlan is used just to test it if it go trough the switch
here are the new configs on the switch to match the new router
config
interface eth1/29-32
speed 40000
switchport trunk allowed vlan 140
no shutdown
exit
Both servers are connected to the 3132Q switch via Mellanox ConnectX-3 adapter and cisco QSFP-40G-SR4 transceiver
here is what you had requested :
switch# show interface status
Eth1/29 UPLINK_PF connected trunk full 40G QSFP-40G-SR4
Eth1/30 UPLINK_PF connected trunk full 40G QSFP-40G-SR4
Eth1/31 UPLINK_ESX connected trunk full 40G QSFP-40G-SR4
Eth1/32 UPLINK_ESX connected trunk full 40G QSFP-40G-SR4
switch# show interface trunk
Port Native Status Port
Vlan Channel
Eth1/29 1 trunking --
Eth1/30 1 trunking --
Eth1/31 1 trunking --
Eth1/32 1 trunking --
Port Vlans Allowed on Trunk
Eth1/29 140
Eth1/30 140
Eth1/31 140
Eth1/32 140
Port Vlans Err-disabled on Trunk
Eth1/29 none
Eth1/30 none
Eth1/31 none
Eth1/32 none
Port STP Forwarding
Eth1/29 none
Eth1/30 none
Eth1/31 none
Eth1/32 none
Port Vlans in spanning tree forwarding state and not pruned
Port Vlans Forwarding on FabricPath
Eth1/29 none
Eth1/30 none
Eth1/31 none
Eth1/32 none
switch# show mac address-table
Legend:
* - primary entry, G - Gateway MAC, (R) - Routed MAC, O - Overlay MAC
age - seconds since first seen,+ - primary entry using vPC Peer-Link
VLAN MAC Address Type age Secure NTFY Ports/SWID.SSID.LID
09-26-2018 11:32 PM - edited 09-26-2018 11:37 PM
As you can see vlan 140 is not forwarding in any of the ports, let's see if there is anything wrong with STP:
- show spann vlan 140 detail
**Edit, have you created vlan 140 at all?
conf t
vlan 140
name XX
exit
ADP
09-25-2018 01:34 PM
Hello
It could be due to various ressons, As the router/fw is performing the routing it correct you should have a trunk on the nx-os facing the router.
Can you first validate you connectivity from the nx-os towards the router/fw?
From the nx-os:
sh ip route
sh ip route static
sh ip int brief
09-29-2018 09:11 AM - edited 09-29-2018 09:13 AM
hello
Sorry I forgot to create the vlan 140 and after I did I've got connection, now I can ping from the router/fw to server, but not the way around something is still missing
here is again
Vlan Channel
Eth1/29 140
Eth1/30 140
Eth1/31 140
Eth1/32 140
Eth1/29 none
Eth1/30 none
Eth1/31 none
Eth1/32 none
Port STP Forwarding
Eth1/29 140
Eth1/30 140
Eth1/31 140
Eth1/32 140
Eth1/29 none
Eth1/30 none
Eth1/31 none
Eth1/32 none
Legend:
* 140 0050.XXXX.XXXX dynamic 159430 F F Eth1/31
* 140 0050.XXXX.XXXX dynamic 159680 F F Eth1/29
09-30-2018 04:55 AM
Ping is bidirectional, if you can ping from A to B on the same LAN but not from B to A it must be some sort of ACL/COPP limiting this kind of traffic. I would say you have to check if the firewall has the interface enabled for ping or if the ACLs/policy are allowing the traffic.
I don't think there are any other problems.
HTH,
ADP
09-30-2018 08:40 AM
Hello
Does the server have the correct subnet and D/g?
sh ip arp x.x.x. ( server )
Can you post the config of the switch
10-02-2018 10:19 AM
hello
currently trying to get from int eth1/1-2 ROUTER to int eth1/16 and eth1/26 SERVER
the server is set to DHCP and on eth1/16 have to get ip on vlan10 and eth1/26 to get ip from vlan11
nothing is happen
!Time: Tue Oct 2 16:40:35 2018 version 6.0(2)U6(7) hostname xxxxxxxxxx no feature telnet cfs eth distribute username admin password 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx role network-admin banner motd #xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx# ssh key rsa 2048 ip domain-lookup ip access-list copp-system-acl-eigrp 10 permit eigrp any 224.0.0.10/32 ipv6 access-list copp-system-acl-eigrp6 10 permit 88 any ff02::000a/128 ip access-list copp-system-acl-icmp 10 permit icmp any any ip access-list copp-system-acl-igmp 10 permit igmp any any ip access-list copp-system-acl-ntp 10 permit udp any any eq ntp 20 permit udp any eq ntp any ip access-list copp-system-acl-pimreg 10 permit pim any any ip access-list copp-system-acl-ping 10 permit icmp any any echo 20 permit icmp any any echo-reply ip access-list copp-system-acl-routingproto1 10 permit tcp any gt 1024 any eq bgp 20 permit tcp any eq bgp any gt 1024 30 permit udp any 224.0.0.0/24 eq rip 40 permit tcp any gt 1024 any eq 639 50 permit tcp any eq 639 any gt 1024 70 permit ospf any any 80 permit ospf any 224.0.0.5/32 90 permit ospf any 224.0.0.6/32 ip access-list copp-system-acl-routingproto2 10 permit udp any 224.0.0.0/24 eq 1985 20 permit 112 any 224.0.0.0/24 ip access-list copp-system-acl-snmp 10 permit udp any any eq snmp 20 permit udp any any eq snmptrap ip access-list copp-system-acl-ssh 10 permit tcp any any eq 22 20 permit tcp any eq 22 any ip access-list copp-system-acl-stftp 10 permit udp any any eq tftp 20 permit udp any any eq 1758 30 permit udp any eq tftp any 40 permit udp any eq 1758 any 50 permit tcp any any eq 115 60 permit tcp any eq 115 any ip access-list copp-system-acl-tacacsradius 10 permit tcp any any eq tacacs 20 permit tcp any eq tacacs any 30 permit udp any any eq 1812 40 permit udp any any eq 1813 50 permit udp any any eq 1645 60 permit udp any any eq 1646 70 permit udp any eq 1812 any 80 permit udp any eq 1813 any 90 permit udp any eq 1645 any 100 permit udp any eq 1646 any ip access-list copp-system-acl-telnet 10 permit tcp any any eq telnet 20 permit tcp any any eq 107 30 permit tcp any eq telnet any 40 permit tcp any eq 107 any ipv6 access-list copp-system-acl-v6routingProto2 10 permit udp any ff02::0066/128 eq 2029 20 permit udp any ff02::00fb/128 eq 5353 30 permit 112 any ff02::0012/128 ipv6 access-list copp-system-acl-v6routingproto1 10 permit 89 any ff02::0005/128 20 permit 89 any ff02::0006/128 30 permit udp any ff02::0009/128 eq 521 ip access-list copp-system-dhcp-relay 10 permit udp any eq bootps any eq bootps class-map type control-plane match-any copp-icmp match access-group name copp-system-acl-icmp class-map type control-plane match-any copp-ntp match access-group name copp-system-acl-ntp class-map type control-plane match-any copp-s-arp class-map type control-plane match-any copp-s-bfd class-map type control-plane match-any copp-s-bpdu class-map type control-plane match-any copp-s-dai class-map type control-plane match-any copp-s-default class-map type control-plane match-any copp-s-dhcpreq class-map type control-plane match-any copp-s-dhcpresp match access-group name copp-system-dhcp-relay class-map type control-plane match-any copp-s-dpss class-map type control-plane match-any copp-s-eigrp match access-group name copp-system-acl-eigrp match access-group name copp-system-acl-eigrp6 class-map type control-plane match-any copp-s-glean class-map type control-plane match-any copp-s-igmp match access-group name copp-system-acl-igmp class-map type control-plane match-any copp-s-ipmcmiss class-map type control-plane match-any copp-s-l2switched class-map type control-plane match-any copp-s-l3destmiss class-map type control-plane match-any copp-s-l3mtufail class-map type control-plane match-any copp-s-l3slowpath class-map type control-plane match-any copp-s-mpls class-map type control-plane match-any copp-s-pimautorp class-map type control-plane match-any copp-s-pimreg match access-group name copp-system-acl-pimreg class-map type control-plane match-any copp-s-ping match access-group name copp-system-acl-ping class-map type control-plane match-any copp-s-ptp class-map type control-plane match-any copp-s-routingProto1 match access-group name copp-system-acl-routingproto1 match access-group name copp-system-acl-v6routingproto1 class-map type control-plane match-any copp-s-routingProto2 match access-group name copp-system-acl-routingproto2 class-map type control-plane match-any copp-s-selfIp class-map type control-plane match-any copp-s-ttl1 class-map type control-plane match-any copp-s-v6routingProto2 match access-group name copp-system-acl-v6routingProto2 class-map type control-plane match-any copp-s-vxlan class-map type control-plane match-any copp-snmp match access-group name copp-system-acl-snmp class-map type control-plane match-any copp-ssh match access-group name copp-system-acl-ssh class-map type control-plane match-any copp-stftp match access-group name copp-system-acl-stftp class-map type control-plane match-any copp-tacacsradius match access-group name copp-system-acl-tacacsradius class-map type control-plane match-any copp-telnet match access-group name copp-system-acl-telnet policy-map type control-plane copp-system-policy class copp-s-selfIp police pps 500 class copp-s-default police pps 400 class copp-s-l2switched police pps 200 class copp-s-ping police pps 100 class copp-s-l3destmiss police pps 100 class copp-s-glean police pps 500 class copp-s-l3mtufail police pps 100 class copp-s-ttl1 police pps 100 class copp-s-ipmcmiss police pps 400 class copp-s-l3slowpath police pps 100 class copp-s-dhcpreq police pps 300 class copp-s-dhcpresp police pps 300 class copp-s-dai police pps 300 class copp-s-igmp police pps 400 class copp-s-eigrp police pps 200 class copp-s-pimreg police pps 200 class copp-s-pimautorp police pps 200 class copp-s-routingProto2 police pps 1300 class copp-s-v6routingProto2 police pps 1300 class copp-s-routingProto1 police pps 1000 class copp-s-arp police pps 200 class copp-s-ptp police pps 1000 class copp-s-vxlan police pps 1000 class copp-s-bfd police pps 900 class copp-s-bpdu police pps 12000 class copp-s-dpss police pps 1000 class copp-s-mpls police pps 100 class copp-icmp police pps 200 class copp-telnet police pps 500 class copp-ssh police pps 500 class copp-snmp police pps 500 class copp-ntp police pps 100 class copp-tacacsradius police pps 400 class copp-stftp police pps 400 control-plane service-policy input copp-system-policy hardware profile portmode 32x40G hardware profile front portmode qsfp snmp-server user admin network-admin auth md5 xxxxxxxxxxxxxxxxxxxxxxxxxx priv xxxxxxxxxxxxxxxxxxxxxxxx localizedkey vlan 1 vlan 2 name LAN vlan 10 name MGMT_P vlan 11 name MGMT_S vlan 12 name MGMT_SERV vlan 140 name TEST vrf context management ip route 0.0.0.0/0 192.168.xx.xx interface Ethernet1/1 description ROUTER switchport mode trunk interface Ethernet1/2 description ROUTER switchport mode trunk interface Ethernet1/3 description UPLINK_R320 interface Ethernet1/4 description UPLINK_R320 interface Ethernet1/5 interface Ethernet1/6 interface Ethernet1/7 interface Ethernet1/8 interface Ethernet1/9 interface Ethernet1/10 interface Ethernet1/11 description UPLINK_SERVER_1 switchport mode trunk interface Ethernet1/12 description UPLINK_SERVER_1 switchport mode trunk interface Ethernet1/13 interface Ethernet1/14 interface Ethernet1/15 interface Ethernet1/16 description UPLINK_WIN_2016 switchport access vlan 10 interface Ethernet1/17 interface Ethernet1/18 interface Ethernet1/19 interface Ethernet1/20 interface Ethernet1/21 interface Ethernet1/22 interface Ethernet1/23/1 speed 10000 description TRUNK_X1052P switchport mode trunk no shutdown interface Ethernet1/23/2 description TRUNK_X1052P switchport mode trunk no shutdown interface Ethernet1/23/3 description TRUNK_X1052P switchport mode trunk no shutdown interface Ethernet1/23/4 description TRUNK_X1052P switchport mode trunk no shutdown interface Ethernet1/24/1 speed 10000 description TRUNK_SG500X_48 switchport mode trunk no shutdown interface Ethernet1/24/2 description TRUNK_SG500X_48 switchport mode trunk no shutdown interface Ethernet1/24/3 description TRUNK_SG500X_48 switchport mode trunk no shutdown interface Ethernet1/24/4 description TRUNK_SG500X_48 switchport mode trunk no shutdown interface Ethernet1/25 interface Ethernet1/26 description UPLINK_WIN_2016 switchport access vlan 11 interface Ethernet1/27 interface Ethernet1/28 interface Ethernet1/29 description UPLINK_3064_X switchport mode trunk interface Ethernet1/30 description UPLINK_3064_X switchport mode trunk interface Ethernet1/31 description UPLINK_3064_X switchport mode trunk interface Ethernet1/32 description UPLINK_3064_X switchport mode trunk interface mgmt0 description MGMT_0 vrf member management ip address 192.168.xx.xx/24 line console line vty boot kickstart bootflash:/n3000-uk9-kickstart.6.0.2.U6.7.bin boot system bootflash:/n3000-uk9.6.0.2.U6.7.bin
10-02-2018 09:25 PM
10-03-2018 11:42 PM
A few questions:
- Why do you have 2 interfaces going to the router without a Port-Chanel?
- How is your router configured? If you have a command line on it post the show run
- Post a show mac address-table
I think you are almost done with this, just need to better connect/configre the router
ADP
10-04-2018 03:33 AM
Hello
My Router/Firewall is pfSense Installed on Dell R320 and Chelsio T580-SO-CR network controller with 2x40G ports
Some VLANs are going trough NIC1 and some trough NIC2 they are not in LAGG.
NIC1 - cxl0
NIC2 - cxl1
Do I still have to create a port-channel on the switch?
10-04-2018 05:07 AM
No in this case a Port-Channel is not required, but as a best practice I would trunk only the required vlans on eth 1/1 and eth1/2.
Are you still in the case where the pfsense can ping the server but the server cannot ping the pfsense?
