Stratix 5700 - Configuration Print Out
Paul Alan
I need to print out a hard copy of many (100+) STRATIX 5700 network switch configurations. Can anyone help?
Is there a particular software package that can do this as the normal web config tool does not have this facility.
Thanks Paul.
Manish Manwal
ssh or telnet switch in putty . save logging in putty for all session. the file is save in text format print out that text file
THANKS
MANISH MANWAL
Mohamed Alhenawy
Hello Paul Alan ,
Good day , as i understand you wanna like copy all the configurations on the Device so you can use Putty application
from www.Putty.org and open application direct , After that choose  " Logging " from left list after that you will find four Option ( None- Printable output - SSH Packets _ All session output ) as per your target choose second option ( *Printable output*) after that browse and choose location file as you wanna to save it  , after that go back to Session and Write Ip address of device which you want and apply this command
>enable
# Terminal Length 0
# show running-config
Done , now check the file you find all configuration there
