Basic vlan help
Skyamoebe551
Needing help with setting up the specifications on the switches. I have started with the three switches but not sure where to start off from there. Down below are the specifications needed.
Create a packet tracer that has 3 Cisco 2960 switches, with each connected to the others (Trunked) using the Gigabit Ethernet Ports.
Create your own sub-netted layer 3 IP scheme.
Add a series of end devices to each switch, (PC1-PC15).
     PC1-6 on S1
     PC7-12 on S2
     PC13-15 on S3
Create VLANs 10(IT), 20(Students), 30(Instructors) on each switch.
Assign the following for VLAN 10:
     SW1, FastEthernet 0/1-10
     SW2, FastEthernet 0/1-6
     SW3, FastEthernet 0/1-15
Assign the following for VLAN 20:
     SW1, FastEthernet 0/11-16
     SW2, FastEthernet 0/7-12
     SW3, FastEthernet 0/16-20
Assign the following for VLAN 30:
     SW1, FastEthernet 0/17-24
     SW2, FastEthernet 0/13-18
     SW3, FastEthernet 0/21-24
The following PC's should be able to communicate:
VLAN 10:
  PC1, PC2, PC7, PC8, PC13
VLAN 20:
  PC3, PC4, PC9, PC10, PC14
VLAN 30:
  PC5, PC6, PC11, PC12, PC15
*Will not allow me to add packet tracer file.
I have set up a basic network, according to your requirements. The PCs do not have IP addresses assigned. I have created three DHCP pools on S2, you can take this addressing scheme for reference, and manually assign the IP addresses to your PCs.
7 Replies 7
Skyamoebe551
this file has only 3 switches , not links, no configs;
Regards, ML
**Please Rate All Helpful Responses **
Yes I am suppose to connect them via (Trunked) using the Gigabit Ethernet Ports. Was not sure how to do that and then create the rest of the list. I don't think any configurations are needed.
Martin L
You should go via Free Net Academy course about PT, how to use it, what is for and what can u do in PT, etc.
PT has GUI config section for some of configs, (not real on real devices),  so You do not need to know some commands but those are:
to make port access one command is
switchport mode access
to add port into vlan commands are
switchport access vlan 10
to add vlans, command is vlan x
To make trunking port command is "switchport mode trunk"
Regards, ML
I have taken a couple I just need further help I am stuck and need a jump start.
Use Tutorials under PT Help menu; http://tutorials.ptnetacad.net/tutorials80.htm
also there are working samples of files under PT Files > Open samples
Regards, ML
