Batch Create 4000 VLANs
schmitgreg
Community Member
Hi all,
Huawei switches have a simple option to generate many VLANs (especially useful for when you want to trunk VLANs through the switch). All you do is enter "vlan batch 2 - 4000" and VLANs 2 through 4000 will be created.
Does Cisco have a version of this for their higher end switches that support all 4094 VLANs?
-gns
Rolf Fischer
Level 11
Level 11
I haven't tried that yet but you could use a simple TCL script like this:
Switch# tclsh
Switch(tcl)# set i 2; while {$i < 4001} {ios_config "vlan $i"; incr i}
Switch(tcl)# tclquit
Rolf
Rolf Fischer
Level 11
Level 11
Switch# tclsh
Rolf
