07-27-2016 01:33 PM - edited 03-08-2019 06:47 AM
Hi all,
I have 6509 stand alone, and I will add a second 6509 and configure vss, when I connect both devices and create the virtual switch can I loose the configuration of the 6509 that I have in production?
Thanks.
Solved! Go to Solution.
07-27-2016 02:04 PM
Hi;
First if you want to configure the VSS on standalone catalyst 6509, your catalyst 6509 supervisor should support VSS (Part # start from VS-).
To configure the VSS you need downtime. Once you convert your switch into VSS, it will loss all the configuration and you need to redo configuration of switch.
Logically your 2 physical switches become single virtual switch and your Switch-1 module start from G1/X/X & Switch-2 module start from G2/X/X.
Thanks & Best regards;
07-27-2016 02:04 PM
Hi;
07-28-2016 06:46 AM
Do you have any doc about how will each module will start with?
thanks.
07-28-2016 07:35 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Besides needing a VSS capable sup (i.e. the VS-S70 or the sup2T), be aware line cards are more limited than those that will work in non-VSS mode.
You should find all the documentation you need Cisco's main web site.
07-28-2016 08:06 AM
Hello Joseph,
I have the following supervisor vs s720 10g / s72033_rp-IPSERVICESK9_WAN-M / Version 12.2(33)SXH.
My question is, will I loose all the config on the working devices?
Thanks.!
07-28-2016 09:27 AM
Disclaimer
Posting
I'm unsure as I've never set up a VSS pair from scratch.
However, I would suspect you'll lose the whole config at least on the switch being added to the VSS pair. Also, if you don't lose the whole config on the "original" VSS device, interfaces are renamed to reflect which of the two VSS boxes the interface resides. So, you'll likely, minimally, lose that part of a config too.
07-28-2016 11:02 AM
Hi all
I have the last question this is the
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXH4, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)"
should I update the IOS version ?
thanks.
07-28-2016 10:02 AM
Hi;
To configure the VSS you need to convert your standalone switch to VSS mode. which will lose all your configuration.
With reference to configure VSS:
With reference to VSS Q&A:
With reference to Module & Interface starts:
Take example you have 2 Catalyst 6509E fully loaded chassis.
Port # start with GX/Y/Z:
Where X = Chassis no. (i.e 1-2)
Where Y = Module no. (i.e 1-9)
Where Z = Interface no. (i.e 1-48)
Now Gigabit interface 1 on module 1 on Chassis-1/Switch-1 will be G1/1/1.
Gigabit interface 20 on module 8 on Chassis 2/switch-2 will be G2/8/20
