baud rate 9600
kaustubhchavan
why we select baud rate 9600 in hyp terminal
My guess is, it might have something to do with 9600 once was often the fastest speed many RS-232 interfaces offered. Later RS-232 interfaces offered even faster speeds, but the default on Cisco was left at 9600. On the newer devices that support faster rates, pushing the rate up can considerable reduce the time for XMODEM file transfers.
5 Replies 5
andrew.prince
Level 10
Level 10
Is this a serious question?
Joseph W. Doherty
Usually that's the default speed for most Cisco console ports.
is there any specific reason behind that ?
Thanks atleast u giv me some satisfactory answer.
