PXE fails over ethernchannels ?
jjpeyrache
hello
my customer configured severals blade servers connected to C3120,most of them
are PXE clients, and only one with Ethernechannels trunks is PXE Server.
PXE clients were unable to download image
only ip address is provided under Channel trunks, removing channel leaving
only one port or PXE server cure problem..
so are any advice regarding PXE over Ethernchannel trunck (GIGA running 802.3ad)
thanks in advance
JYP
owillins
Level 6
Level 6
To resolve this issue, check each of the following network configuration items:
• DHCP services are not available on the network to which the PXE-enabled NIC is connected.
• A DHCP proxy or IP helper address is not configured for the subnet on which the PXE client is connected.
• The switch port connected to the PXE NIC is running Spanning Tree Protocol, EtherChannel Protocol, or Port Aggregation Protocol and is thus not activated immediately when a link is detected. This forces the DHCP request from the PXE client to timeout.
• DHCP is available on the network, but PXE is not.
• The network cable is not attached to the PXE-enabled NIC on the target server
since PXE works without ethernchannel
i assume networks and servers are ok
this is purely an Configuration issue between
PXE and etherchannels
i do not know where can i dig into
JYP
