Beginner Needing Help!
david_morganl
Community Member
Hi All,
I've just got myself a placement gap year with a networking company and have decided to get my CCNA along the way (all paid for =] )
I have just bought some 2950 switches and I am currently going through and learning from different places all of the stuff I need.
I came across one command which does not work though which is;
Davids-Switches(config)#crypto ?
% Unrecognized command
Im currently trying to set up SSH and due to the IOS (from what ive read) this does not work and it seems as though the current IOS does not support SSH at all.
I've done a sh ver as follows;
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(19)EA1c, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 02-Feb-04 23:29 by yenanh
Image text-base: 0x80010000, data-base: 0x8058A000
ROM: Bootstrap program is C2950 boot loader
Davids-Switches uptime is 16 minutes
System image file is "flash:/c2950-i6q4l2-mz.121-19.EA1c.bin"
cisco WS-C2950-24 (RC32300) processor (revision N0) with 20808K bytes of memory.
Processor board ID FOC0820Z0HJ
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:11:20:CE:64:40
Motherboard assembly number: 73-5781-12
Power supply part number: 34-0965-01
Motherboard serial number: FOC08201ZB0
Power supply serial number: DAB081787AQ
Model revision number: N0
Motherboard revision number: B0
Model number: WS-C2950-24
System serial number: FOC0820Z0HJ
Configuration register is 0xF
Could somone please advise me;
1) Is this device compatible with any sort of IOS upgrade?
2) How would I acutally do it? (the walkthrough guides on cisco are a bit long winded and confusing)
3) If this switch is not compatible, what switch would you recommend for CCNA training for under £100?
This has been a problem which I have been looking at for days, trying to troll the web for any help or suggestions is useless unless Im going to read some 1000 page long description.
Can you please help me?
Thank you very much in advance!
David Morgan
2 Accepted Solutions
Wilson Bonilla
Level 8
Level 8
Hello David.
First of all: You need a Crypto image to support SSH in your switches.
The current version your switches is runnining (
flash:/c2950-i6q4l2-mz.121-19.EA1c.bin)  doesn't support SSH feature.
The exact same switch you have is SSH capable, you just need to have upgrade the IOS image. For example:
c2950-i6k2l2q4-mz.121-22.EA14.bin <== Notice the K goes for Kripto(Crypto) feature.
Here is the software upgrade to perform the IOS upgrade.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_example09186a0080169627.shtml
N/A keep using your switch, even when it's a very old switch in deed it supports sshv2 in the latest release.
Regards.
Wilson B.
Please rate if useful!
Hi David.
If you have a CSCO then you can log in to the cisco.com.
-> go to support.
-> go to switches
-> select 2950
-> select 2950-24
-> download the desire image.
or you can try this link
http://software.cisco.com/download/release.html?mdfid=270568146&flowid=2394&softwareid=280805680&release=12.1.22-EA14&relind=AVAILABLE&rellifecycle=ED&reltype=latest
Regards.
Wilson B
10 Replies 10
Wilson Bonilla
Level 8
Level 8
Hello David.
Regards.
Wilson B.
david_morganl
Community Member
Hi Wilson,
Thanks for the speedy help! what you said just pretty much sums it all up and makes it easier to understand!
I have tried following these steps but get stuck at downloading the .bin file.
I think the download link on the page is dead ---> http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=268438038
I keep on getting the unavaliable page, is there another part of the cisco downloads page where I can get this or do you know if this is just temporary maintenance?
Cheers!
David
Hi David.
-> go to support.
-> go to switches
-> select 2950
-> select 2950-24
Regards.
Wilson B
You my friend are very helpful!!
Davids-Switches#sh ver
IOS (tm) C2950 Software (C2950-I6K2L2Q4-M), Version 12.1(22)EA14, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by cisco Systems, Inc.
Compiled Tue 26-Oct-10 10:35 by nburra
Image text-base: 0x80010000, data-base: 0x80680000
Davids-Switches uptime is 0 minutes
System image file is "flash:c2950-i6k2l2q4-mz.121-22.EA14.bin"
I learnt some new things slong the way also =] I got my solarwinds TFTP server set up and also connected via the Vlan to my PC, set up the default gateway and IP addresses on the switch and PC.
It took a while but now its done!
login as: david
C
WELCOME TO DAVIDS [email protected]'s password:
Access denied
C
WELCOME TO DAVIDS SWITCH
Davids-Switches>en
Password:
Davids-Switches#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Thank you very much!
David
Hi David.
Glad to hear it worked.
Regards.
Wilson B
Hi David,
Just to add up to the above replies, in order to simply verify whether your current image supports SSH or not:-
Look for the letter "k" in the name of your image, if it is present then that is the indicator of Crypto support in the image.
For example c2960-lanbasek9-mz.122-52.SE.bin
Rajmohan R
david_morganl
Community Member
Hi Again,
Again, im looking for software upgrades, i think im just going to ask which one to upgrade to each time as there are so many, I just cannot find the right one.
This time im looking for an upgrade for my 2621 router. The version is below, its not allowing me to do the command 'encapsulation dot1q' while trying to create a trunk port.
I mean, i just need the most up-to-date version and im unsure which one to get from the downloads page (which I found due to your previous help thank you very much)
Theres about 21 different downloads on there and being completley new to cisco (hopefully rapidly gaining knowledge with peoples help) I am at a complete loss of which to get?
I thought mabye looking for one with an 'i' in there because thats the type I seem to have now, I have seen the ones with 'k' in there which again thanks to your help i understand to be crypto supporting, that may be useful...but just a general heads of which one to go for would be nice
David-2621#sh ver
IOS (tm) C2600 Software (C2600-I-M), Version 12.3(5), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 28-Oct-03 05:07 by kellythw
Image text-base: 0x80008098, data-base: 0x80CA4288
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
David-2621 uptime is 3 hours, 43 minutes
System image file is "flash:c2600-i-mz.123-5.bin"
cisco 2621 (MPC860) processor (revision 0x600) with 61440K/4096K bytes of memory.
Processor board ID JAD05330AF9 (3909200233)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
8 Low-speed serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Thank you in advance!
David
Hi David
"its not allowing me to do the command 'encapsulation dot1q' while trying to create a trunk port."
Ideally we cant create Trunk / Access ports (switchport) in Routers (C2621).
"encapsulation dot1q" command cant be applied on Physical interface of a router.
Your need to break down the Physical interface into subinterfaces and try executing "encapsulation dot1q" command.
For example, Assuming your hosts are in vlan 10 and if Gi0/0 of your router is connected to your LAN switch (Trunk port with vlan 10 allowed in trunk link)
int gi0/0
no ip add
int gi0/0.10
ip address ip_address subnet_mask (default gateway for your hosts in Vlan 10)
encapsulation dot1q 10
Try this and check IP reachability to this IP from any of your hosts in LAN and let  me know if you are facing any problem.
Rajmohan R
Rajmohan R
Hi Raj,
I should have really been more clear on my previous comment, I had created fa0/0.10 and fa0/0.20 and was trying to configure it on these virtual ports and that encapsulation command did not work whilst in these virtual ports interfaces, so it would not allow me to do this.
David M
Hi David,
Latest IOS release for your router seems to be 12.4.25d (Maintenance Deployment) released on Aug 10.
Based on Memory availability on your router, I suggest to upgrade the IOS image to the following one:
IP BASE with Crypto support -  c2600-ipbasek9-mz.124-25d.bin  (DRAM / Flash:  64MB / 16MB)
Rajmohan R
Rajmohan R
