Behavior of EIGRP and ISIS routing not as expected
Can_networking
I three 2811 routers setup as follows:
Traffic enter R1 via fast ethernet port 0
R1 is connected to R3 via a 115200 b/s serial link
R1 is connected to R2 via fast ethernet connection
R2 is connected to R3 via fast ethernet connection
Traffic exits R3 from fast ethernet port 1
In summary
R1-R3 is a short path with low bandwidth
and R1-R2-R3 is a long path with high bandwidth
I noticed the following behavior with the following routing protocols
1) RIPv2, path R1-R3 is selected, unless I fail the serial link then path R1-R2-R3 is selected. This is expected since it is a distance based protocol
2) OSPF, path R1-R2-R3 is selected, unless I fail the etherlink R1-R2 then path R1-R3 is selected. This is expected since it is a state based protocol
3) BGP behaves like RIPv2 for the same test. This is expected since it wants to minimize transit costs.
4) However with EIGRP and ISIS routing I get contrary results to what I expected.
EIGRP behaves like OSPF, I would have expected it to behave like RIPV2 (a distance based protocol) ???
ISIS behaves like RIPv2 , I would have expected it to behave like OSPF (a state based protocol) ???
2 Accepted Solutions
Peter Paluch
The path choice in routing protocols is determined by the nature of metrics they are using - not by the underlying type of the routing protocol (whether it is distance-vector or link-state).
EIGRP takes the minimum bandwidth and total delay into the computation of the resulting metric. The higher the minimum bandwidth is, the lower - and better - the metric. So EIGRP basically prefers the same quality that OSPF prefers - the bandwidth of the route toward the destination. That makes EIGRP do the same choice as OSPF in your network.
With IS-IS, there is no automatic recomputation of interface bandwidth into IS-IS costs, contrary to OSPF. All IS-IS interfaces have the default cost of 10, regardless of their speed. Running IS-IS in this network essentially makes it prefer paths with the least total numbers of links to the destination, and that is why IS-IS appeared to make the same choice as RIP.
Once again, the way a routing protocol makes its best path selection is based on the nature of the metrics it is using. The underlying mechanism of a routing protocol affects the overall information about the network that the routing protocol can collect. In distance-vector protocols, routers send messages that contain arrays (in software engineering, an array = a vector) of {Network, Distance} entries toward known destination networks. In link-state protocols, routers send messages that contain information about each particular router and its links to its adjacent objects (other routers or network). In distance-vector protocols, none of the routers knows how the entire network precisely looks like. In link-state protocols, every single router knows precisely how the entire network looks like.
Feel welcome to ask further!
Best regards,
Peter
the interface costs of the IS-IS routers must be user provisioned and then the network can behave like an OSPF network based on link state.
If you want IS-IS to differentiate between faster and slower links, then you are correct - you have to manually configure interface costs so that faster interfaces have a lower IS-IS cost, and vice versa. However, regardless of the cost setting, IS-IS is a link-state protocol just as OSPF, and it always makes its decisions based on link-state rules. Just with all interfaces left at their default cost of 10, IS-IS treats every interface as equal.
Best regards,
Peter
6 Replies 6
Peter Paluch
Best regards,
Peter
Thank you Peter for your excellent reply.
I did some further research and found a useful command for EIGRP
show ip eigrp topology 192.168.1.0 255.255.255.0
It clear shows the BW, distance (in terms of delay), load  and reliability metrics used for the routing decision.
My understanding from the second part of your answer is that the interface costs of the IS-IS routers must be user provisioned and then the network can behave like an OSPF network based on link state.
Best regards,
Peter
Thanks Peter,
It all makes sense now.
You are welcome :)
Best regards,
Peter
