Best Cisco match for Extreme networks x450g2 and x460g2
vstrikovic1999
Hello everyone,
I was wondering, if you could help me with my task in a fast way.
I just need to find Cisco counterpart for Extreme Networks switches x450g2 and x460g2, let's say best fit.
Thanks in advance.
Veselin
balaji.bandi
I can see near by Cat 9K Models (Cat 9300 and Cat 9500) - depends budget you can go to models
Cat 9300 spec as below :
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-architecture-cte-en.html
Cat 9500 does not have PoE (more focussed on Core)
If you looking for chassis Cat 9400 is a good option with a Modular
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9400-series-switches/nb-06-cat9400-architecture-cte-en.html
BB
5 Replies 5
Joseph W. Doherty
As many of us are probably not familiar with the Extreme Network switch product line, it would be helpful if you would describe what switch features you need and/or provide a reference link to datasheets for those Extreme Network switch models.
vstrikovic1999
Of course, i forgot to attach files.
First image considers x450g2 series, second one x460g2.
Regards.
balaji.bandi
BB
I also thought about Cat9300, would be a great deal!
Thanks for your fast responses.
Veselin
make sure you also look at the License tier, essential (basic features)  and network advance (most features  and advanced you get)
BB
