Best Design OSPF with Stub Area or Not
Rowlands Price
Hi Support,
I have two L3 switches connected with OSPF with backbone are 0
switch 2 as many vlans with interface vlans created for users
it's better to create a stub area zone in switch 2 ?
What is the best design
regards
I thinks, i will use stub are and using summary, SW1 will only summary and no E1 and no E2
21 Replies 21
It depends on Router must know vlan IP or not.
MHM
Hi MHM
Router is also on area 0, my concern is about SW2, the interface toward SW1 is on OSPF area 0, working fine.
do it's necessary to create on SW2 a second zone (stub area) for only connected interfaces (vlans)
EDIT
Router to SW1 there is static route (correct)
config NSSA area x between sw1-sw2
Config vlan in area 0 in sw2
Dont redistrubte direct in SW2 for vlan subnet instead config ospf under each vlan SVI.
Now you isolated your network via NSSA and make router know vlan subnet IP.
MHM
Router is for WAN connections and it' has static route to remote office.
SW2 is catalyst L3 not Nexus, if i do not distribute connected vlan subnet, SW2 will not inject theses ip to area 0
i'm right? Thanks
MHM
Hi MHM
find below the config of SW2
SW2#sh running-config
hostname SW2
ip routing
no ip domain lookup
vlan 2,21-22
vlan 23
name DATA-SW3
vlan 24
name DATA-SW4
vlan 25
name DATA-SW5
vlan 26-27
vlan 28
name DATA-SW6
vlan 28
name DATA-SW6
vlan 29
name WIFI1
vlan 30
name WIFI2
vlan 31-33,55,100-103
vlan 168
name V168
vlan 999
name NATIF
interface Loopback0
ip address 10.4.20.33 255.255.255.255
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
shutdown
negotiation auto
interface GigabitEthernet1/0/1
switchport access vlan 27
switchport voice vlan 100
spanning-tree portfast
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
description "PORT DEDIE AU WIFI"
switchport access vlan 26
switchport mode access
interface GigabitEthernet1/0/4
interface TenGigabitEthernet1/1/1
description Link CNSS-SIEGE-CORE1
no switchport
ip address 10.4.80.50 255.255.255.252
ip pim sparse-mode
ip ospf network point-to-point
ip ospf dead-interval minimal hello-multiplier 4
load-interval 30
carrier-delay msec 0
auto qos trust dscp
service-policy input AutoQos-4.0-Trust-Dscp-Input-Policy
service-policy output AutoQos-4.0-Output-Policy
interface Vlan2
ip address 10.4.20.1 255.255.255.224
interface Vlan21
ip address 10.4.21.1 255.255.255.128
ip helper-address 172.16.100.5
interface Vlan22
ip address 10.4.22.1 255.255.255.128
interface Vlan23
ip address 10.4.23.1 255.255.255.128
interface Vlan24
ip address 10.4.24.1 255.255.255.128
interface Vlan25
ip address 10.4.25.1 255.255.255.128
interface Vlan26
ip address 10.4.26.1 255.255.255.128
interface Vlan27
ip address 10.4.27.1 255.255.255.128
interface Vlan28
ip address 10.4.28.1 255.255.255.128
interface Vlan32
ip address 10.4.32.1 255.255.255.128
interface Vlan33
ip address 10.4.33.1 255.255.255.128
interface Vlan55
ip address 10.4.55.1 255.255.255.128
interface Vlan100
ip address 10.4.34.1 255.255.255.128
interface Vlan101
ip address 10.4.35.1 255.255.255.128
interface Vlan102
ip address 10.4.36.1 255.255.255.128
interface Vlan103
ip address 10.4.37.1 255.255.255.128
interface Vlan168
ip address 172.16.168.1 255.255.248.0
router ospf 1
router-id 10.4.20.33
area 20 stub no-summary
timers throttle spf 10 100 5000
timers throttle lsa 10 100 5000
timers lsa arrival 80
passive-interface default
no passive-interface TenGigabitEthernet1/1/1
network 10.4.20.0 0.0.0.31 area 20
network 10.4.20.32 0.0.0.31 area 20
network 10.4.21.0 0.0.0.127 area 20
network 10.4.22.0 0.0.0.127 area 20
network 10.4.23.0 0.0.0.127 area 20
network 10.4.24.0 0.0.0.127 area 20
network 10.4.25.0 0.0.0.127 area 20
network 10.4.26.0 0.0.0.127 area 20
network 10.4.27.0 0.0.0.127 area 20
network 10.4.28.0 0.0.0.127 area 20
network 10.4.32.0 0.0.0.127 area 20
network 10.4.33.0 0.0.0.127 area 20
network 10.4.34.0 0.0.0.127 area 20
network 10.4.35.0 0.0.0.127 area 20
network 10.4.36.0 0.0.0.127 area 20
network 10.4.37.0 0.0.0.127 area 20
network 10.4.55.0 0.0.0.127 area 20
network 10.4.80.48 0.0.0.3 area 0
network 172.16.168.0 0.0.7.255 area 20
SW2#
Did you try NSSA between SW1 and SW2 ?
Why you decide to use stub in Core SW?
MHM
Hi MHM
i didn't try NSSA between SW1 and SW2
maybe my diagram is little false, SW1 and SW2 collasped distrbution switches, so, the ospf backbone area 0 is on the both switches.
SW1 and SW2 has vlans configured with on theirs SVI.
i did and test 2 options
Option 1: on each sw2 used the command redistribute connected subnets, with this option on others switches, the routes are O E2
Option 2: on sw2 used a stud area no-summary, with with option, i have the same result on others switch, but the routes are O IA
my question, what is better, using option 1 or 2
I read your post and select of answer' and my concern is lsa5.
We definitely know static will add as lsa5 so that we effect our design'
Our design must not include any stun (totally stub).
It can contain NSSA or standard.
Since you correct the info of the two SW must in area 0 (which mandatory for any DC) then you dont use stub and NO NEED OIA instead use E1/E2 with redistrubte connect (easy way).
Good luck freind
MHM
Hi MHM,
The best way is use redistribute connected subnets instead using a stub area righ?
i tested, the two options are working fine with redistributed connected subnets and using stub area on switch with vlans.
on thing, with using stub area, i can summarize the network on the stub area,
finally, what is the best option?
SW1-SW2-many vlan's
SW1-SW2 is area0 backbone (allow lsa1/2/3/4/5)
So using area in SW 2 and redistrubte vlan and use summary is the ideal solution. (Summary can use with any area).
The SW1 will see only summary.
Now stub config in SW2 what will advertise if all vlan is redistrubte as E1/E2?
MHM
I will run lab to test router as ASBR and ABR and redistrubte and summary.
The SW2 will be ABR and ASBR in same time I meed to see effect on ospf db.
I will update you later tonight
MHM
Good idea friend, will waiting your update
