Best Design OSPF with Stub Area or Not
Rowlands Price
Hi Support,
I have two L3 switches connected with OSPF with backbone are 0
switch 2 as many vlans with interface vlans created for users
it's better to create a stub area zone in switch 2 ?
What is the best design
regards
21 Replies 21
Just curious, why all the alternating /25s?
Also, BTW, do you know you could replace the shown OSPF network statements with just two such statements?
Hi Joesph, /25 is because we used a vlan per switch and we didn't have more than 50 users by switch, so we choose reduce the mask from /24 to /25
You misunderstand my question.
Why didn't you assign consecutive /25s, not just bottom half of /24.
New question, is no more than 50 users, why not use /26?
BTW, my prior employer actually ran out of private address space, although they had to work at it.  ; )
Hi Joseph, sorry, i misunderstand your question
you are righ, normally we must summurized all ip range
M02@rt37
Hello @Rowlands Price
Stub areas are often used to reduce OSPF routing information, especially in scenarios where there are many routes and you want to optimize the routing table.
If Switch 2 has a large number of external routes or participates in a complex network, using a stub area might help reduce the size of the OSPF database and improve routing efficiency.
If the number of routes in Switch 2's routing table is a concern, using a stub area can help by limiting the flooding of external routes into the area.
On the other hand, if Switch 2 needs to have complete routing information and needs to participate in the OSPF backbone area, a stub area may not be appropriate.
Best regards
Hi M02@rt37
Thanks for you message,
SW2 is a L3 with only vlans (about 10 vlans maxi) with SVI, no routers or others nodes behind SW2
Joseph W. Doherty
Stubs are used to keep other area routes from entering a non zero area.  So how many routes would otherwise enter the candidate stub area?
