Showing results forĀ
Search instead forĀ
Did you mean:Ā
Best Method to Connect Cisco 3945 to Catalyst 6500 VSS in Dual Home Mode
satish_zanjurne
Level 4
Level 4
I want to connect Cisco 3945 with a single /30 subnet to Catalyst 6500 VSS in dual home mode  , what should be the best way ?
Reza Sharifi
Since the 6500s are VSS, you can use an EtherChannel
Thanks Reza    i forgot that router supports L3 etherchannel...
