Negative Interface Control counters on fa interface
ajaju
Community Member
Hi all,
I have a query regarding an HWIC-2FE module on a Cisco 3845 router.
The show controllers output shows negative counter for InUnicasts and InGoodOctets and I would like to know what it means.
Here is the output of show controllers fa0/0/1:
wc2437-r2-OLD#sh controllers fastEthernet 0/0/1
Interface FastEthernet0/0/1
 HWIC Registers
 Status = 0x2700            Control = 0x335
Intr Event= 0x0     SMI Spd = 0x6
Marvell switch registers=0x43800800
Number of Packets received with errors:
Bad Marvell Trailer: 0   Packets received
Marvell PHY (1) Register:
Reg 29 = 0x4380087A         Reg 30 = 0x4380087C
Control    : 0x100          Status      : 0x784D
Identifier : 0x141  0xC89
Auto Neg   : 0x1E1          Auto Neg Exp: 0x4
LP Ability : 0x0            LP NxtPg    : 0x0
PHY ctrl   : 0x4130         PHY status  : 0x2C40
Intr enable: 0x400          Intr status : 0x0
Port (1) Registers:
Status     : 0x3A00         Control     : 0x77
Identifier : 0x831          Vlan Map    : 0x2200
VID and PRI: 0x2            Rate Control: 0x30
Port Asc Vt: 0x2
TX counter : 0xEE           RX counter  : 0x15F2
Port (CPU PORT=9) Registers:
Identifier : 0x831          Vlan Map    : 0x2002
Port Asc Vt: 0x200
TX counter : 0x15F2         RX counter  : 0xF0
 Software MAC address filter(hash:length/addr/mask/hits):
  0x00:  0  ffff.ffff.ffff  0000.0000.0000       115
  0x2D:  0  001f.ca58.fbe7  0000.0000.0000 -298152099
  0x58:  0  0100.5e00.0006  0000.0000.0000         0
  0x5B:  0  0100.5e00.0005  0000.0000.0000         0
  0xC0:  0  0180.c200.0002  0000.0000.0000         0
  0xC0:  1  0100.0ccc.cccc  0000.0000.0000         0
  0xC5:  0  0180.c200.0007  0000.0000.0000         0
ATU table:
   Mac Address     |   Ports   |  Entry State  | dbnum
00-1F-CA-58-FB-E6  |    0x100   |     0x0F   |  0x01
1F-CA-58-FB-E6-00  |    0x200   |     0x0F   |  0x02
FE unit = 0
Counters Names Port=1, CPU_PORT=9
        InUnicasts      = -293659729, 263600355
        InBroadcasts    = 119, 63
        InPause         = 0, 0
        InMulticasts    = 0, 52707
        InFCSErr        = 0, 0
        AlignErr        = 0, 0
        InGoodOctets    = -1835494382http://www-tac.cisco.com/Teams/ks/images/topic.pnghttp://www-tac.cisco.com/Teams/ks/images/csc.png, 1339715564
        InBadOctets     = 0, 0
        Undersize       = 0, 0
        Fragments       = 0, 0
        In64Octets      = 1724907743, 932581161
        In127Octets     = 548797536, -1 662073437
        In255Octets     = 551520051, -959709782
        In511Octets     = 209367092, 461161551
        In1023Octets    = 219105611, 413034618
        InMaxOctets     = 747609653, 1078659014
        Jabber          = 0, 0
        Oversize        = 0, 0
        InDiscards      = 0, 0
        Filtered        = 0, 0
        OutUnicasts     = 263600354, -293659728
        OutBroadcasts   = 63, 119
        OutPause        = 0, 0
        OutMulticasts   = 52707, 0
        OutFCSErr       = 0, 0
        OutGoodOctets   = 1339715492, -1835493253
        Out64Octets     = 932581161, 1724907743
        Out127Octets    = -1 662073438, 548797536
        Out255Octets    = -959709782, 551520051
        Out511Octets    = 461161551, 209367092
        Out1023Octets   = 413034618, 219105611
        OutMaxOctets    = 1078659014, 747609654
        Collisions      = 0, 0
        Late            = 0, 0
        Excessive       = 0, 0
        Multiple        = 0, 0
        Single          = 0, 0
        Deferred        = 0, 0
        OutDiscards     = 0, 0
Please advise on the same.
Thanks in advance.
Zizhen Gao
This is certainly a bug.I believe that CSCtn95356 was opened to address this?
zz
ajaju
Community Member
Hi Zizhen,
thanks for your reply.
I had actually opened that bug myself when this issue occured.
Was hoping to get a quick solution from the CSC (from past expereinces of all users) coz the bug may take a lot of time to resolve.
Guess I will have to wait for it to be resolved then.
I have actually recreated this issue in the Cisco Lab and I found that when the counter value goes above 2147483647 (this is the highest 31-bit number), the counter becomes negative ( -2147483647;as soon as it becomes a 32 bit number). The counter value then keeps incrementing towards the positive side, and once it reaches 2147483647 again, it becomes negative again and this process keeps continuing.
Although this does not have any affect on the functioning of the router or of any interface as such, the counter going negative does not make any sense whatsoever. So this is more of an enhancement bug, which needs some looking into.
Aniruddha
