Best place to apply QOS
roger perkin
Level 2
Level 2
I would like to limit the bandwidth used by a host at a remote site but only to a specific server.
Where is the best place to apply the policing?
1: the Core switch that the server is plugged into
2. The Wan switch
3. On the service provider router (have to pay!)
4. on the remote switch
Also is policing the best way to go - I just want to limit user to specific server to 1Mb
Roger
Shashank Singh
Hi Roger,
Policing can be done on any of the above devices mentioned. However, there are two best practices when it comes to policing:
++Policing should be done as close to the source as possible.
++Whenever possible, policing should be done in Catalyst hardware rather than Cisco IOS Software.
If we go by the above guidelines, the best place to police the traffic is the 3750 switch to which host (traffic source) is connected. Please be informed that 3750 platform supports policing in hardware and only on ingress.
Let me know if there are more questions and please rate this post if your query is answered.
Shashank
Shashank,
If you say the best place to apply QOS is as close to the source as you can - why not the 6509?
If a user is requesting a lot of traffic from the server - is the server the source?
Roger
Hi Roger,
Yes server is the source for the return traffic. However if you apply the policer on the 6509 near the server, only the server data will be policed to less than 1 Mb. If data from server is the only data that is coming to the host, this will be as good as having the policer near the host. But if the host is accessing other resources also, say internet, then total ingress at the server may be more than 1 Mb.
Hope that was helpful.
Shashank
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Assuming the problem is you don't want this particular server impacting other traffic if it generates lots of traffic, I would suggest deprioritizing its bandwidth usage so it effectively only has access to unused bandwidth.
