port-asic stats enqueue, different firmware versions, different output?
Ton V Engelen
Level 3
Level 3
Hi, all.
i hope someone can explain whats going wrong here. Or maybe i m doing something wrong?
As i am checking qos on our network, i ran into this.
I have 3750 switches and use Version 12.2(25)SEE2 and also Version 12.2(50)SE2 on a couple of 3750 switches.
The output on
sh platform port-asic stats enqueue port x asic y
is different in th firmware versions.
First
sh mls qos interface FastEthernet 1/0/19 statistics
FastEthernet1/0/19
dscp: incoming
0 - 4 : 1826189 0 0 0 0
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 0
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 346680 0 0 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
dscp: outgoing
0 - 4 : 2627192 0 756 0 6
5 - 9 : 0 6 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 0
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 8 0 0 0 0
45 - 49 : 0 54893 0 748554 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
cos: incoming
0 - 4 : 1403479 0 0 0 0
5 - 7 : 799054 0 0
cos: outgoing
0 - 4 : 2617812 0 0 0 0
5 - 7 : 138772 748554 0
Policer: Inprofile: 0 OutofProfile: 0
sh platform pm if-numbers
sh platform port-asic stats enqueue port 20 asic 1
Port-asic Port Enqueue Statistics - Details
RxQueue Enqueue Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 52
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 1339991741
Weight 1 Frames 349475
Weight 2 Frames 1324219979
Queue 3
Weight 0 Frames 5748448
Weight 1 Frames 327336859
Weight 2 Frames 3302639
Port 20 TxQueue Enqueue Statistics
Queue 0
Weight 0 Frames 256050
Weight 1 Frames 0
Weight 2 Frames 187353
Queue 1
Weight 0 Frames 340379300
Weight 1 Frames 148069156
Weight 2 Frames 45183894
Queue 2
Weight 0 Frames 426
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 44501516
Weight 1 Frames 0
Weight 2 Frames 15339868
This seems correct to me. RX queue 2 and 3 and TX queue 0-3 have incrementing counters. Seems like input and output queueing is working
But now this, btw, the configuration is exactly the same on both switchports. Only difference is that the firmware version is different.
Fa1/0/19 21 21 19 1/20 1 19 21 local Yes Yes
Version 12.2(50)SE2,
sh mls qos interface FastEthernet 3/0/30 statistics
FastEthernet3/0/30 (All statistics are in packets)
dscp: incoming
0 - 4 : 599585 0 0 0 0
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 57195
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 92799 0 0 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
dscp: outgoing
0 - 4 : 20540694 3307 9247 327 1378
5 - 9 : 0 972 0 1673 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 11 0 4731 0
20 - 24 : 0 0 0 0 35333
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 15 0 39
35 - 39 : 0 0 0 0 0
40 - 44 : 22 0 0 0 0
45 - 49 : 0 65997 0 981604 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 70 0 0 0
60 - 64 : 0 0 0 0
cos: incoming
0 - 4 : 611459 0 0 57195 0
5 - 7 : 92799 2 0
cos: outgoing
0 - 4 : 20590198 1673 4742 35333 54
5 - 7 : 87478 996892 70
output queues enqueued:
queue: threshold1 threshold2 threshold3
queue 0: 0 0 66019
queue 1: 272 2361223 1789789
queue 2: 0 0 4796
queue 3: 1673 0 20560590
Fa3/0/30 142 142 30 0/7 3 30 34 remote No Yes
sh platform port-asic stats enqueue port 7 asic 0
Port-asic Port Enqueue Statistics - Summary
RxQueue 0 Enqueue Stats: 1079316357
RxQueue 1 Enqueue Stats: 76272407
RxQueue 2 Enqueue Stats: 0
RxQueue 3 Enqueue Stats: 0
Port 0 TxQueue Enqueue Stats: 0
Port 1 TxQueue Enqueue Stats: 0
Port 2 TxQueue Enqueue Stats: 0
Port 3 TxQueue Enqueue Stats: 0
Queue 0
Weight 0 Frames 0
Weight 1 Frames 1079316357
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 4699764
Weight 2 Frames 71572643
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Port 7 TxQueue Enqueue Statistics
Queue 0
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 1
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 2
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
Queue 3
Weight 0 Frames 0
Weight 1 Frames 0
Weight 2 Frames 0
The question, why do i see all zero's here? I would expect to see counters != 0 on RX queue 2 and 3 and TX queue 0-3, not all zero's like this?
Like there is no traffic at all and no queueing at all? I m sure there is traffic going on.
Am i missing something with firmware version 12.2(50)SE2 ?
Shashank Singh
Hi Ton,
One reason why this command is not working can be because you are executing this from the CLI of the master switch and switch 3 is a member in the stack.
Can you try going to the CLI of switch 3 (session 3) and doing this output again?
Another reason could be the fact that we have swapped the port and asic numbers. A better command to avoid this confusion is "sh platform pm platform" which gives the asic and port number clearly.
interface gid gpn lpn asic hw-i flags sp dp bundle vlan mvid mac so_di i_vlan
Fa1/0/1   3   3   1   1    2       U  2  2  no     0    0    0   61443  0
Fa1/0/2   4   4   2   1    3       U  2  2  no     0    0    0   61444  0
By the way, you can see the port asic stats directly using the command "sh platform port-asic stat enqueue fa3/0/30"
Please rate this post if it helped answer your query.
Shashank
5 Replies 5
Shashank Singh
Hi Ton,
Shashank
Hi, Shashank
this could be very well the issue i m running in to. So I m going to check the items you mentioned and let you know the outcomes.
For now, thanks very much in advance!
ps. I guess this means that "show platform port-asic stat drop fa3/0/30" will work too like this
Again, i ll let you know the outcomes
Hi, Shashank
that was it, again thanks a lot.
ps. show platform port-asic stat drop fax/0/y works also.
Hi Ton,
Thanks for the reply. Great to know that it works!
Cheers,
Shashank
Hi again,  Shashank and all.
i found out some more and its exactly what i need  :-)
Example: i want to look at the queue' s of lets say Fa 3/0/30, and get the if-numbers and see its port 7 asic 0
I execute show platform port-asic stat enqueue port 7 asic 0, then i see all zeros in the queue's. (Like my first question was)
I now execute session 3
And then issue the same command
show platform port-asix stat enqueue port 7 asic 0
Here are my queue's. Cool!!
So i understand now that i always need to issue session x when issuing "show platform port-asix stat enqueue port x asic y" to get the desired output. (depending on the switchport i want to look at)
Plus this command also shows the input queueing, so this approach is my favorite.
Thanks again :-)
You ve been a BIG help here!
