04-26-2018 09:13 AM - edited 03-08-2019 02:48 PM
What is the Best practice to uplink a WS-C3750-24PS-S stack of 5 to redundant distrubution switches?
In the event if 1 of the 5 WS-C3750-24PS-S stack switches fails could the stack still work minus the down switch in the stack connecting to the upstream distribution switches?
Solved! Go to Solution.
04-26-2018 09:33 AM
Use a Portchannel and put the physical links in it. Depending on the amount fiber, optics and the availability you need, I would say a minimum of 2 10Gig links (one from the master and one form the switch that will be the master when the first master fails) up to 4 10Gig.
That is correct. if the master fails, whichever switch you have configured with the highest priority will take over packet forwarding
04-26-2018 09:33 AM
04-26-2018 09:37 AM
