max DRAM capacity of 3750X-48P-S and 3750X-24P-S?
aotholland
Hi all,
I have a questions about DRAM memory en Flash capacity of 3750X-48P-S and 3750X-24P-S.
I have finded the following.
Performance Numbers for All Switch Models
Switching Fabric
160 Gbps
DRAM
256 MB (512 MB for 3750X-12S and 3750X-24S)
Flash
64 MB (128 MB for 3750X-12S and 3750X-24S)
Cisco Catalyst 3750X-48P-S (IP-Base feature set)- 256Mb Dram and 64 Mb flash (x2)
Cisco Catalyst 3750X-24P-S (IP-Base feature set)- 512 Mb Dram and 128 Mb flash (x3)
Is that possible?
Kind Regards.
Arumugam Muthaiah
Hi Ali,
You are right. The above mentioned DRAM capacity supported by Cisco Catalyst 3750-X.
Apart from this, There is USB Type A port in the back of the Cisco Catalyst 3750-X and 3560-X Series. This is the additional storage. This USB port can be used to perform software upgrades, store configurations, and even write memory core dumps for troubleshooting purposes. All Cisco USB memory drives can be used (currently up to 1-GB USB drives are available).
All available Cisco USB flash memory devices can be used
Table 4. Cisco USB Flash Memory Devices
Product ID
Description
MEMUSB-64FT
64MB USB Flash Token
MEMUSB-128FT
128MB USB Flash Token
MEMUSB-256FT
256MB USB Flash Token
MEMUSB-1024FT
1GV USB Flash Token
Refer:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/qa_c67-578933.html
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
Hi Aru,
Thanks a lot.
Kinds Regards,
Ali.
Hi Ali,
Pleasure to support
Aru
jesnowakb
Hi Everyone!
I currently have a WS-C3750X-48P-S with memory problema (usage 88%) is there a way I can purchase more memory for this switch?
