Best practices for creating names/description for switch links
schulcz
Hi Guys!
I’m thinking about a good naming scheme for switch-to-switch, switch-to-router, switch-to-firewall, switch-to-server (and so on) links that are informative enough, transparent (the backbone and access ports are spectacularly separated at first glance), but still not too long (e.g. --- === xxxxx === ---). I don't like overly long names because they usually lose the point. For example, when I'm using a "show int statu" command, I'm usually forced to use the "show int descr" command as well to see what I looking for, which slows down the troubleshooting or configuration process.
I’ve seen plenty of methods in client networks in recent years, but I couldn’t tell which one was the most practical.
I wonder who uses what method to form the names? (e.g. for simple links or for aggregated links and so on..)
Thanks!
balaji.bandi
we generally follow naming convention :
Site = (can be company short)  EX : BB
Localtion : area of the switch EX : CEN
Building :
Floor :
serving switch :
BB-CEN-BLD02-ACC1
BB-CEN-BLD02-ACC2 - if you have 2 stack switch there.
is this works for you ?
BB
Reza Sharifi
switch-to-switch
source sw-1 to destination sw-2 port 1/1/1 to 3/2/8
description: to-5th-flr-sw-2 port 3/2/8
source sw-2 to destination sw-1 port 3/2/8 to 1/1/1
description: to-8th-flr-sw-1 port 1/1/1
switch-to-firewall
description: to-1st-flr-fw-1 port 1/1
firewall to switch
description: to-2nd-flr-sw-3 port 3/5/1
or
description: to-5th-flr-3750-2 port 3/2/8
description: to-8th-flr-4500-1 port 1/1/1
And so on...
you can usually add more characters up to 32.
Giuseppe Larosa
Hello @schulcz ,
I usually use something like
interface x/y
desc  to  <remote-hostname>:<remote-interface>
with a host naming convention that tells the role of the device SW RT FW in the first two letters of the hostname.
Hope to help
Giuseppe
