Cisco 877 unknown reboot reason
w.alalami
Hello
i have a running 877 without any issues since 2 years, but recently it start to reload accidentally without any reason and every time i lose part of the configuration (DHCP configuration) so i need to reconfigure it again.
i updated the ios from 124-15.T4 to 124-24.T8, now the configuration is stable even after reload, but the reload problem still exist. is there any solution?
Sh ver output:
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 12.4(24)T8, RE LEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Sun 09-Sep-12 09:09 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
LAFICO uptime is 2 days, 15 hours, 9 minutes
System image file is "flash:c870-advsecurityk9-mz.124-15.T4.bin"
Note: the new ios was written over the the old ios without changing the file  name.
6 Replies 6
balaji.bandi
you need to Look for crash log why this was rebooted. here is troubleshoot guide,
1. any power issue ?
2. any CPU high load ?
3. how long this device up before it was rebooted automatically.
4. what kind of Load it is handling ?
5. is this for  home purpose router or business ?
6. is there any other device rebooted at same time.
https://www.cisco.com/c/en/us/support/docs/universal-gateways-access-servers/90-series-customer-premises-equipment/7900-crashes-router-troubleshooting.html
BB
Sorry for my late replay.
1. any power issue ? NO other devices running well.
2. any CPU high load ? NO load at all since facing this issue.
3. how long this device up before it was rebooted automatically. max 2 hours.
4. what kind of Load it is handling ? i use it to access my network through VPN
5. is this for  home purpose router or business ? Home
6. is there any other device rebooted at same time. No, its the only cisco device i own, other devices are running well.
Can you post show version - may be some bug, or suggest to capture the logs.
BB
i tried to upgrade the ios to 15.1, i still have the same reboot issue.
LAFICO#sh ver
Cisco IOS Software, C870 Software (C870-ADVSECURITYK9-M), Version 15.1(1)T5, REL EASE SOFTWARE (fc2)
Compiled Mon 07-May-12 18:46 by prod_rel_team
LAFICO uptime is 49 minutes
System image file is "flash:c870-advsecurityk9-mz.151-1.T5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 877 (MPC8272) processor (revision 3.0) with 118784K/12288K bytes of memory.
Processor board ID FCZ1218943Y
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
4 FastEthernet interfaces
1 ATM interface
1 Virtual Private Network (VPN) Module
128K bytes of non-volatile configuration memory.
24576K bytes of processor board System flash (Intel Strataflash)
marce1000
                                   >Note: the new ios was written over the the old ios without changing the file  name.
 - I would advice to use standard upgrade and installation procedures from Cisco , especially when dealing with issues such as you are experiencing. Use show version as a sanity check as to query the current version running. Besides other reply also use a syslog-server as a log collector and also use an snmp-trap receiver for all traps. The intend is also to be able to watch for problems during normal behavior. Indeed  you can then also look for last-gasp information when a device reboots.
 M.
Thanks sir, i will do the necessary to collect these info.
