Best Practices for Switches
tahirs001
I have been tasked with the following scenario and need some help and suggestion on how i would tackle this?
In my organisation we have over a hundred Cisco switches all placed over Europe, I need to create one build for all sites so that all switches have the same settings i.e. IOS version, Security settings, Vlans (one for voice & one for data)
Is there any best practices which i can follow? also how what is the best tool to control all of these switches?
Tahir
Mathias Garcia
I would go to www.cisco.com/go/srnd
and have a look on their guides.
For example http://www.cisco.com/en/US/docs/solutions/Enterprise/Branch/Design.html or others depending on your need.
Some simple stuff to do. Sepparate management traffic from user traffic. Use ssh for remote access instead of telnet/http.
Secure vty lines and snmp communities with acl's. dhcp snooping. run autoqos voip (unless you have some other specific QoS needs).
Enable portfast on access ports. perhaps look into dot1x. service password-encryption. configure aaa (radius/tacacs).
Edit: forgot about logging. use ntp, a syslog server and configure service timestamps log] datetime msec.
glen.grant
http://www.cisco.com/en/US/products/hw/switches/ps700/products_white_paper09186a00801b49a4.shtml#cg1
This is a best practices doc for IOS switches.  For other best practices just plug in "best practices" into the search line on the main cisco page.  As far as managing  you can get Ciscoworks  though it can get pricey .  Some people us tools from vendors like  Solarwinds  who makes good monitoring and troubleshooting tools .
