best way to configuration switch port
alialhameed94
I have three ISPs with the same database. Every customer has the potential to change the server every day.I'm using vlan50 to manage all device ,Which means that each port contains 2 Vlan (Management Vlan [50] and Service Vlan [10 or 11 or 12]). Note that the service Vlan in the customer side can not be selected.
khldk
If I understand you correctly:
int gi1/0/1
desc client1
switchport mode trunk
switchport trunk native vlan 10
switchport trunk allowed vlan 10,50
exit
6 Replies 6
khldk
int gi1/0/1
desc client1
exit
I've done this before. But I have some problems like broadcast storm.
does Native vlan affect on switching performance?
The Native Vlan mismatch will not generate a significant problem but you will be receiving a lot of alerts. By default the native vlan is 1, a best practice is change it by other vlan (used just with this role) on both ends but I dont think the carriers change that.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Julio E. Moisa
If you are receiving each ISP through specific VLAN the switchport should be configured like:
CORE SW
vlan 10
name ISP1
vlan 11
name ISP2
vlan 12
name ISP3
vlan 50
name MANAGEMENT-VLAN
interface g1/0/1
description ISP1
switchport access vlan 10
switchport mode access
no shutdown
interface g1/0/2
description ISP2
switchport access vlan 11
no shutdown
interface g1/0/3
description ISP3
switchport access vlan 12
no shutdown
interface g1/0/4
description MANAGEMENT-ROUTER
switchport access vlan 50
no shutdown
interface g1/0/5
description CLIENT3-ISP3
no shutdown
interface g1/0/6
description CLIENT2-ISP2
no shutdown
interface g1/0/7
description CLIENT1-ISP1
no shutdown
If they are different clients, I dont see the reason to exchange information between them unless the same client is using different gateways for redundancy otherwise trunk interfaces should be configured on the client and core sw ports.
Hope it is useful
That wouldn't work since he is managing downstream devices, which is why he needs vlan 50 tag'ed - on the upstream ISP ports you are correct though, they should be access ports only.
Considering the setup you could also apply an incoming ACL on the ISP facing interfaces since firewalls seems to be missing as well.
Every customer is connected with me by (PTP Wireless Link) and i have to monitor this devices, every link from ISP have his own subnet and gateway.
For EXP:
vlan 10 subnet from ISP 10.49.221.0/24
vlan 11 subnet 10.16.33.0/24
so how can I management client without using on vlan.
