01-26-2014 09:41 AM - edited 03-07-2019 05:48 PM
Team:
I am not sure if this is really needed; however, I am looking at methods or solutions that I can get interfaces stats from my switches and routers. Looking for errors: CRC, Frame, Overruns, Collisions, etc; however, I am not sure the best way to do this on my devices.
Currently looking into Expect; however, I do not see away that I can save the output of the ‘show interface’ command to a file, clear the counters, and upload the interface stats to a tftp site. The idea was to use a cron job and ‘grep’ to dig though the files once on my server, but again, I am not sure I can do this.
I am looking for suggestions on how I can do this, or something similar, or even a better solution.
JJ
Solved! Go to Solution.
01-26-2014 10:05 AM
Solarwinds Orion NPM will do this. You could script it and it shouldn't be too hard, but if you have a lot of routers or interfaces, you may want something a little more robust unless this is for personal use. Personally, I would look into Python to do your scripting though if you're pretty comfortable with scripting.
HTH,
John
*** Please rate all useful posts ***
01-26-2014 10:05 AM
HTH,
John
01-26-2014 12:12 PM
Hi John,
Thanks for the insight. I am currently learning Python, which is slow going, but I am pushing through. This is production, and last Friday I did a router and switch count. It will be over 200 devices distributed globally. In addition, these resources/devices are linked to as many different circuit types. The business is small, and I cannot get the budget for Solarwinds, so I was trying to be creative. I looked into Python, but I am just learning, yet I have started with the Apress ‘Beginning Python’ by Hetland, so the skill set is not there YET.
01-27-2014 07:09 AM
You can also google "free network management tools" and see if any of them might meet your needs .
