Best way to LAG Catalyst 9500 to a SG350xg
redgasgiant
I've been experimenting with connecting the "core" 2 stackwised 9500(which supports Pagp and LACP)  to the "edge" SG350(which supports just LACP?).
The LAG on the 9500 consists of 2 25gb ports 1/0/1 and 2/0/1  and the LAG on the SG350 is 2 10gb ports XG3 and XG4
I have the LAG set to LACP on both sides, (ACTIVE mode on the 9500 and it's just a 'enable LACP" checkbox on the SG350)
Is that the best way? Should I be using PAGP or some other different mode on the switches?
Is that the best way? Yes this is best way
Should I be using PAGP or some other different mode on the switches? No need lacp better than pagp
 The best way on this case is the way it works. You said you have :
"I have the LAG set to LACP on both sides, (ACTIVE mode on the 9500 and it's just a 'enable LACP" checkbox on the SG350)"
Does it works? If does, then this is the best way. If not, then, it is not.
The way I would probably config
SG350
switchxxxxxx(config-if)# channel-group 1 mode on
9500
