BGP Advertisement Question
lamav
Level 8
Level 8
I have a question regarding BGP advertisements.
I have an iBGP peer whose parameters are the following:
router bgp 65000
no synchronization
bgp log-neighbor-changes
network 0.0.0.0
timers bgp 15 45
neighbor AS65000 peer-group
neighbor AS65000 remote-as 65000
neighbor AS65000 password 7 02000B490F0408310C
neighbor AS65000 update-source Loopback0
neighbor AS65000 next-hop-self
neighbor AS65000 route-map Ford-Internal-Routes-Only out
neighbor AS65000 maximum-prefix 50000 80
neighbor 19.213.1.130 peer-group AS65000
According to this config, the next-hop that should be advertised by this router to iBGP peer 19.213.1.130 is itself.
But thats not the case. This router is acting in the classic BGP fashion, where it learns of a prefix through eBGP and passes the prefix on to its iBGP neighbor with the originating router as the next-hop.
ecc#sh ip bgp nei 19.213.1.130 advertised-routes
BGP table version is 34095654, local router ID is 19.213.1.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 0.0.0.0 19.213.2.106 0 32768 i
*> 4.37.104.132/32 19.213.2.18 20 0 65300 ?
*> 8.17.200.208/28 19.213.2.18 20 0 65300 ?
ecc#sh ip bgp 4.37.104.132
BGP routing table entry for 4.37.104.132/32, version 30991629
Paths: (3 available, best #2, table Default-IP-Routing-Table)
Advertised to update-groups:
2 3 4 5
65300
19.213.2.26 from 19.213.2.26 (19.211.4.2)
Origin incomplete, metric 20, localpref 100, valid, external
65300
19.213.2.18 from 19.213.2.18 (19.211.4.1)
Origin incomplete, metric 20, localpref 100, valid, external, best
65300
19.213.1.1 (metric 130816) from 19.213.1.1 (19.213.1.1)
Origin incomplete, metric 20, localpref 100, valid, internal
ecc#
ecc#sh ip ro 4.37.104.132
Routing entry for 4.37.104.132/32
Known via "bgp 65000", distance 20, metric 20
Tag 65300, type external
Last update from 19.213.2.18 1w5d ago
Routing Descriptor Blocks:
* 19.213.2.18, from 19.213.2.18, 1w5d ago
Route metric is 20, traffic share count is 1
AS Hops 1
Route tag 65300
ecc#
So, notice that ECC learned of this 4.x.x.x prefix from an eBGP neighbor with a next-hop of 19.213.2.18, and it is that next-hop that it passes on to its iBGP neighbor 19.213.1.130.
Why?
What am I missing -- besides a brain?
Victor
Edison Ortiz
Victor,
You won't be able to see the attribute modified on the source router. The attribute is modified as it leaves the router. To verify your suspicion, I recommend checking the receiving router.
Same logic applies when setting an as path-prepend. You don't see the as-path added on the advertised routes, right?
HTH,
__
Edison
Edison Ortiz
Victor,
HTH,
__
Edison
Gotcha!
Thanks, buddy. Youre right.
I would have thought that way if there were an outbound policy attached to the neighbor statement, such as a route map, prefix list, etc. I didnt think that next-hop self would also behave that way.
Thanks again
