How to use xcopy for 3750
I deleted the IOS on a 3750, now I need to use xcopy to reinstall a IOS. I will be loading
c3750-ipservicesk9-mz.122-35.SE5.bin
When I put in the following command:
switch: copy xmodem: flash:c3750-ipservicesk9-mz.122-35.SE5.bin
I get the following result:
Begin the Xmodem or Xmodem-1K transfer now...
CCCCCCCCCCBB0BB0xmodem:: I/O error
Using HyperACCESS and a rool over cable I can communicate with the swich, giving me the following prompt: switch:
I also have access to 3Cdaemon.
Please start from the begining.
chuckwirth
The better way is to use tftpdnld. It requires that you have a tftp server with the IOS on it. You can get a free server from Kiwi or SolarWinds.
Next, plug the switch into the network using any ethernet port.
Turn on the switch and get to the ROMMON prompt.
Follow the example, this assigns an ip address to the switch, gives it a subnet mask and gateway, and tells it where the IOS is. Use all caps:
rommon 1 > IP_ADDRESS=171.68.171.0
rommon 2 > IP_SUBNET_MASK=255.255.254.0
rommon 3 > DEFAULT_GATEWAY=171.68.170.3
rommon 4 > TFTP_SERVER=171.69.1.129
rommon 5 > TFTP_FILE=c3750-is-mz.12.1.bin
rommon 6 > tftpdnld
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
Mark Yeates
Level 7
Level 7
Patrick,
Did you initialize the flash before trying the xmodem transfer?
switch: flash_init
then
Also using tftp_dnld is not available on this model switch.
HTH,
Mark
